Need Suspension HELP!
Old Jul 14, 2006 | 01:24 AM
jonny917's Avatar
I have an 03 DP coupe. Just threw on my 4th set of 20's...Hyper Black TSW Thruxtons 20X8.5 ET20 Front, 20X10 ET25. They sit PERFECT (IMO) and the lip makes me smile every time I looks at it until I see that stupid gap in the wheel well. I wanna SLAM it but dont have the $$$ to go crazy on it. I dont really want to wear the inside of my tires or start messing with the camber/toe, or blow out my shocks either. Preferably just some new springs but I want to get as low as possible. Most Teins just get you down like 1.1 inches which wont turn my frown upside down. Whats the best spring to drop it down as low as possible for a good price without too much camber?? (I dont mind some)
Old Jul 15, 2006 | 05:14 PM
Gsedan35's Avatar
Well, your wanting a high drop amount, but your also not wanting to have the camber change that automatically comes along with it. You'll have to compromise and except less drop or pony up for alignment fixing parts. Since $$ is a issue, can you compromise on a .8" drop, like say fromTein 350Z H-techs?
Old Jul 17, 2006 | 12:05 AM
jonny917's Avatar
.8? thats almost nothing. I wouldnt drop it less than 1.2 even if it was for free camber is cool anyway, it makes the BIG LIP stick out and gives off a badass glare from behind (when clean of course)....we will see how it goes, ive got time.
Old Jul 17, 2006 | 12:10 AM
Zerk's Avatar
The larger the drop the larger the camber/toe issue. So if you really want to slam it, then you may need to consider fixing camber/toe issue unless you are Andrew Firestone and have an unlimited supply of tires.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
