Low-cost lowering of coupe.
Old Jul 22, 2006 | 03:55 PM
SFLG35's Avatar
FGC President
the most cost effective way would be to just cut your stock springs.
since you have an 03 i see from your sig you could get a set of z springs that will lower about 3/4 of an inch. you could probably pick those up for like $50 they would be stiffer and shorter then what you have now. then you could cut those to make it even lower if you wanted.
if you want aftermarket the tein h tech will go about 3/4 of an inch. new they will run around 155. you can most likely find them cheaper used.
when buy tein springs though make sure to get the ones for the 350z because they are stiffer then stock. if you get the ones for the g35 they will be softer then stock.
Old Jul 22, 2006 | 03:57 PM
hai109's Avatar
Originally Posted by SFLG35
your shocks arent goin to go out in a year, but they will go out quicker
when they do go out just buy someone elses stock shocks that they took off when either they went to coilovers or when they bought the tokico or the koni's
Yeah, but then you will have to re-install someone's else's used shocks...I should say about a year or more...They are going to go out faster then normal...
Old Jul 22, 2006 | 05:09 PM
SFLG35's Avatar
FGC President
i know several people that have a lowered g for well over a year now and their shocks havent gone out.
your shocks are not goin to go out in a year just because the springs are shorter. they will over time but not in a year.
even if you are to buy someone elses used shocks and or springs it will still be a lot cheaper then buying new shocks or springs. i would rather buy someone's used shocks for 100 or less then pay 560 for tokico d specs or koni yellows. you would only need those if you are goin to track the car.
Old Jul 22, 2006 | 07:54 PM
phenom1011's Avatar
Originally Posted by aleok
for real? the front kinetex camber a-arm sucks?? why?
I have the new ones. The reason is you still have some negative camber. Get the stillen ones
Old Jul 22, 2006 | 08:00 PM
(>")> G35's Avatar
Originally Posted by dream_G35
350z h-techs...100 used look around. Install yourself $50 (renting spring compressor) no camber issues. and pretty good drop nothing crazy but stays within spec.
FYI, most AUTOZONE's have tools you can barrow, just put down a deposit and return the tool later for your deposit. I've barrowed a spring compressor and O2 sensor socket kit before with no propblems.
Old Jul 29, 2006 | 07:52 PM
a0alvl's Avatar
Hmmmm....... I may wait for SPC's front camber kit to come out.. that's a thought...
Old Aug 9, 2006 | 12:36 PM
bavarian06's Avatar
dream_g35, can you post some pics of your car lowered on Z H-Tech? I'm about to buy Z S-Tech and I'm worried it may be too low (grown too old to be driving side ways over bumps). do you have finger gaps from the tire and fender still? thanks.
Old Aug 10, 2006 | 08:23 PM
a0alvl's Avatar
Hmm I am going with Kinetix front/rear and sportlines by eibach I think... can't find but a couple pics of coupes lowered on them... anyone have any!??!
Old Aug 10, 2006 | 08:44 PM
G Money's Avatar
Be warned, the sportlines will probably be really low. I have the prokit and it's over an inch of drop, probably closer to 1.5. I scrape quite a bit and I run 20's withg 35 series tires, wich raise the car slightly.
Old Aug 10, 2006 | 08:45 PM
a0alvl's Avatar
Eek Hmmmm... I want it pretty damn low (I figure if I'm spending all the money to correct the camber I might as well make a big drop).. it's supposed to be 1.6 in the front and 1.4 in the rear...
Old Aug 10, 2006 | 09:09 PM
Amarao's Avatar
If going the 350Z spring route which are needed? I heard the revised edition springs? With the purple/pink dot on them?
Old Aug 11, 2006 | 05:55 PM
Sputnik's Avatar
I'm in the market to lower my G as well, anybody from South Cali who know a place where I can get mine done for a reasonable price??
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
EasySausage
Sep 24, 2015 01:06 PM
Detailed Image
Sep 11, 2015 08:37 AM
Detailed Image
Sep 8, 2015 02:42 PM
Detailed Image
Sep 4, 2015 08:35 AM
