Low-cost lowering of coupe.
Old 07-21-2006 | 03:39 AM
a0alvl's Avatar
Ok -- BEFORE I get flamed on the usual (Don't put cheap stuff on a luxury car, or search before posting etc.) just hear me out
I have an 03 coupe on 19's and am looking for a 1.25-1.5" drop. I don't want to spend a ton of money to do it as I'll only have the car for a couple years. What's the most affordable yet safe (in terms of suspension not squeeking etc) setup to run to get those results? I obviously want camber adjustments but at those rates do I need them on both the front AND rear? Would toe adjustments really be necessary?
If anyone has a low-cost setup they currently run that's working for them please post the following:
Spring brand/price
Camber brand/price
Toe brand/price
I'm curious what I can do for a good drop AND decent tire wear without breaking the bank~
Old 07-21-2006 | 04:27 AM
drunkin master's Avatar
If you go lower than one inch you will need camber's. Lots of brands out there, I don't know about toe though. I have seen many people on the forum put tein s techs and tein htech for the 350z. I have have espelir gt on right now and the drop is a little less than an inch after it settled.
Try a search and you will find lots of info on the forum. many people have just springs installed. good luck and post some pics of your before and after
Old 07-21-2006 | 06:52 AM
Klubbheads's Avatar
1. tein-s/150$
2. alignment shop with -1.6 to 1.8 rear camber and -1.0 to 1.3 front camber/60-90$
3. I have no idea/0$
Old 07-21-2006 | 03:52 PM
aszatk01's Avatar
i am wondering the same thing!!!
i'm have a set of 350z Eibach Pro Kit i want to put on the ride.
i have the same setup- 03 w/ 19s running on reguar springs.
along his lines...
should i put the pro kit 350z springs on? anyone know for sure how they lower on our cars? i heard that it lowers more than the G35 pro kit springs?!
either way, am i going to NEED a camber kit? or would it just be very wise so i dont wear out my nice tires?
or will i be ok with just the lower and not a camber
if not...its for sale
Old 07-21-2006 | 04:02 PM
Disco_Monkey's Avatar
Spring brand/price - Eibach Prokit $250
Camber brand/price - 350EVO Front $900, Stillen Rear $450
Toe brand/price - Not needed
I also have Tokico D-specs - $550
If you install everything yourself, you will save quite a bit of money. I think my setup was pretty lowcost compared to some people with the $2,000 Coilover kits as well as all the camber adjustment kits. The camber kits will save you money on tires so they pay for itself over time. The stock struts will blowout quicker with lowering springs so you might as well do the struts while you are at it. I have read that there are camber kits that cost a lot less but I can't remember the name... I will post the link for you when I find it. But I DO remember that people said they squeak so I opted not to get those. I think it was called SPC or SBC or something.
Old 07-21-2006 | 04:09 PM
speedracerg35's Avatar
sorry to hijack the topic, but has anyone ever bottomed out on lowered springs w/stock struts?
Old 07-21-2006 | 08:47 PM
a0alvl's Avatar
So.... more than a grand just to lower my baby an inch........ EEK! Any other setups!?
Old 07-21-2006 | 10:20 PM
romanwarrior's Avatar
Cheapest way is to just cut the springs. It will cost you $0 and a few hours in the garage sawing away. Hahaha. Just kidding.
I would just get some TEIN springs for under $200, SPC rear camber arms, and Cusco A-arms for front. This would be the cheapest way if you want it done right and with adjustability.
Old 07-22-2006 | 04:29 AM
patman530's Avatar
Edit...didn't see that you wanted to drop more than 1.25"
Old 07-22-2006 | 06:31 AM
phenom1011's Avatar
I have the pro kit 350
kinetix camber kit 750 front and back... the front sucks
You should just drop it .75 its better than nothing and no camber kit
Old 07-22-2006 | 07:22 AM
aleok's Avatar
for real? the front kinetex camber a-arm sucks?? why?
Old 07-22-2006 | 02:35 PM
SFLG35's Avatar
FGC President
the front only suck if you get the old version.
my roommate has the new version on his car and they dont squeek at all
i have the old version cause i got used ones and they squeek. the difference is the new ones have a grease nipple that allow yo grease up the polly bushings.
for rear correction get the spc camber arms and toe bolt they are the cheapest and work the best.
the cheapest way to lower your car would be just cut your stock springs to the length you want
if you want aftermarkets springs pm with what you are looking for and ill see what i can get for you on a price
Old 07-22-2006 | 02:43 PM
dream_G35's Avatar
350z h-techs...100 used look around. Install yourself $50 (renting spring compressor) no camber issues. and pretty good drop nothing crazy but stays within spec.
Old 07-22-2006 | 04:42 PM
hai109's Avatar
Look around and buy it used...You might as well buy shock while you are at it. Your shocks will go out in about a year...There's a lot of guys that selling used springs when they upgrade to coilovers...
Old 07-22-2006 | 04:51 PM
SFLG35's Avatar
FGC President
your shocks arent goin to go out in a year, but they will go out quicker
when they do go out just buy someone elses stock shocks that they took off when either they went to coilovers or when they bought the tokico or the koni's
