HELP!!! will i need a camber kit???
Old Jul 21, 2006 | 02:55 PM
aszatk01's Avatar
i have a set of 350z Eibach Pro Kit i want to put on the ride.
03 w/ 19s (Ruff Racing) running on reguar springs right now.
245 up front and 275 in the rear (will it rub if i drop???)
anyone know for sure how the 350z Pro kit lower on our cars? i heard that it lowers more than the G35 pro kit springs?!
either way, am i going to NEED a camber kit? or would it just be very wise so i dont wear out my nice tires?
or will i be ok with just the lower and not a camber
if not...its for sale
thanks
Old Jul 21, 2006 | 06:44 PM
sliderg35's Avatar
I heard that the 350 springs lower the same in the rear and a little less in the front. You don't have to get a camber kit, but your tires will wear unevenly if you don't. The stock camber arms are not adjustable, so the only way to get back into spec is to change the arms. Oh - it won't rub as long as you have a hefty offset in the rear +45 or more.
Old Jul 21, 2006 | 06:47 PM
GLuXuRy's Avatar
i believe stock camber arms are adjustable... but only adjustable to max like 2 degrees (maybe less) where as if you get the SPC or another brand of camber arms...they are adjustable to like 4 degrees
Old Jul 21, 2006 | 07:14 PM
Andy2434's Avatar
With either kit you will most likely need a complete camber set-up.
Old Jul 21, 2006 | 07:27 PM
silver g's Avatar
thanks
The drop is virtually the same as the G35 pro kit. Infact the G35 pro kit drops the front 1.1" versus 1.0" for the 350z prokit. The rear is the same 1.0"
Yes you are going to need a camber kit.
Old Jul 22, 2006 | 12:14 AM
aszatk01's Avatar
thanks guys...
so it looks like i should get a complete camber kit?
i have some nice dunlop direzzas with great tread on them so i'd rather not f them up. how much worse is the tread wear?
Old Jul 22, 2006 | 12:16 AM
GLuXuRy's Avatar
it gets pretty bad...i dropped my car on Tanabe NF210s and my camber is horrible...ill be getting my SPC next weekend... i took of my rims and check out the tire wear... its looks ok for now...but i only put like 2k miles on it so i dunno
Old Jul 22, 2006 | 12:25 AM
aszatk01's Avatar
are there any springs i could drop around .75 inches or more so that i wouldn't need a camber kit for?
because i'd rather sell mine and get a more appropriate one where i wouldnt need the camber adjustment
because by time i'm done with it, it'll be around $500 to drop it around an inch...just doesnt seem worth it
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
