Rear coilover adjustment
Old Aug 8, 2006 | 04:36 PM
teamsprock's Avatar
I just put my Stance coilovers on my new G and i was just curious if anyone else running coilovers has resolved the problem of having no access to the top of the strut in the rear. All the cars I have ever dealt with have the rear struts coming into the trunk but not on our G35's. I am considering making a hole in the enclosure (in the trunk) that houses the strut so I can get at the top of the strut without having to remove my suspension just to adjust it.
Old Aug 10, 2006 | 07:50 PM
teamsprock's Avatar
anyone?
no one else has experienced this problem? I can't seriuosly be the only one, unless in my haste to find the strut in the trunk I missed it some how but I'm pretty sure it's hidden. Any advice before I just start removing body panels!!
Old Aug 10, 2006 | 07:58 PM
Alan's Avatar
errr my understanding is that you cant get to the top of the strut easily unless you make a hole... i ended up getting edfc to save me the pain.
Old Aug 12, 2006 | 12:34 AM
Knight's Avatar
Yes I've run into this problem with my Tein coilovers. I just adjusted the dampening to my liking & plan on left it at that setting. I know it's hard to believe you cannot make adjustments from the inside.
Do a search, I've seen post something can be hooked up to the top of the strut, then some sort of the thick wire is run thru the panels & you can adjust from a **** attached to this wire (which is placed in an easy to access spot). Hope you get what I'm saying...
Good luck!
Old Aug 13, 2006 | 02:04 PM
teamsprock's Avatar
thanks
thanks for the post. Thats cool to know that the edfc will work. I am also looking into more solutions. Once I get a chance to dig in to things more i will give an update.
derres
Aug 28, 2015 03:27 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
