Alignment or not?
Old Sep 5, 2006 | 12:16 PM
Knight's Avatar
Alignment or not?
I have my 04 coupe lowered on Tein CS coilovers. I recently upgraded my rims/tires from the OEM 18's to the OEM 19's - no change in vehicle height.
I don't think this is necessary, however I wanted to double check to be safe, do I need to do another wheel alignment? Last thing I want is to have bad tire wear on the new 19's.
I've seen some post(s) indicate a wheel alignment is needed if you change your tires.
Thanks!
Old Sep 5, 2006 | 01:32 PM
kenchan's Avatar
Even at stock height your tires will wear a little more on the inner tread
than outer. that's normal.
since you mentioned you didn't change ride height, just leave it alone and
try it. If you get too much tramlining from the wider and shorter
sidewall tires, then dial in a tad more toe-in. maybe 0.2 to 0.3 more
each side.
Old Sep 5, 2006 | 04:12 PM
Knight's Avatar
Thanks Ken!
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
