NEED INFO 35 series work?
Hey guys I know you'll have the answer for me !
I just got a set of concept neeper moxy's yesterday and they look SICK!!!
Lovin them...however. Where i purchaced them they said that I needed to go with a 30 series tire. Well I am not thrilled with the way they look.
Here are the stats.. 20"x 8.5 in the front with a 30mm offset. 20" x 10" with a 25mm offset in the rears. Question is ;Can I run a 35 series tire without problems. I will not be lowering the car. 03' coupe/non brembo. THANKS!!!
Originally Posted by escobar929
i got 20's and 30 series is perfect
Originally Posted by rwcblkcoupe
I have them on the car now with 30 series. The thing I dont like is the gap at the point where the tire meets the wheel on the rears. Also I thought it would also help to fill the wheel well. thoughts?
gap where the tire meets the wheel? I can't picture that. post a pic.
do you mean the wheel is sticking out farther then the tire, that it's stretched? if that's the case you need a wider tire.
oh you should run a 285/30/20 that is the same diameter as the stock 245/45/18 combo and it will fill out the 10" rim better. see how a 285/30 fills out a 10" wheel.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
vstypicals
Jul 20, 2015 10:55 PM
