350z Springs on G35
350z Springs on G35
I currently have a 2005 G35 Coupe 5at with the regular shocks.
I have talked to Dtor about adding oem 350z springs on his g35.
I was wondering if anyone else put 350z springs on their g35 and
if it was worth it. How much the drop was and if it messed
up their alignment and camber? If camber kit was needed and
how the tire wear was after adding the springs. Revised Vs. Unrevised?
Also would it be better to get the 350z Oem shocks as well?
and would I need spacer for my tires and rims if i currently
have the sport suspension 19in rims but not the actually suspension?
Also is it better to add revised or unrevised 350z springs on the regualr
stock shocks on my g35.
Thanks.
Thanks.
i suggest you do a search.
you might consider researching revised and unrevised springs.
tons of people do this. its not uncommon..
all i can say is extreme4377 did it and its a waste of money (he finally switched to 350z h techs) lol no offense andrew
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
