Stoptech Brakes Maintenance Question
Old Oct 20, 2006 | 11:19 AM
BombRush's Avatar
I have stoptech brakes on my G and I was just wondering,
How much mileage is recommanded for brake pad change?
How much mileage is recommanded for rotor change?
I still get Brake squeak time to time, what is the cause of this?
Help would be great ^^
Old Oct 22, 2006 | 02:41 PM
BombRush's Avatar
any recommandation? =(
Old Oct 22, 2006 | 03:53 PM
absolutg's Avatar
workin...
why don't u ask stoptech directly? for that much coin, they definitely provide good support
Old Oct 23, 2006 | 02:22 PM
StopTech's Avatar
1. Depends on your driving style and type of driving
2. Ditto
Brakes squeak because of small vibrations. Usually a good bed-in solves the issue. Even if you bedded in the pads when they were new, if not driven aggressive enough, the brakes have a tendancy to unbed themselves, so it's good to do another bed-in.
Old Oct 24, 2006 | 03:09 AM
BombRush's Avatar
I drive everyday gently..... Never Track or race...
Just regular everyday driver.
Old Oct 24, 2006 | 09:31 AM
Q45tech's Avatar
Perfection would require that you examine the system closely every 3-6 months measuring the pad wear RATE so you can get an idea WHEN the 3>2 mm replacement of pads is necessary.
When you replace pads disassemble the calipers and clean and test dust boots and caliper piston seals. Flush and replace the brake fluid annually. Measure the rotor thickness and measure the rotor runout and correct as necessary.
Most people don't maintain brakes very well.
miata007
Aug 17, 2015 04:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
