Did Aftermarket Wheels Caused this?
Old Oct 24, 2006 | 03:07 AM
BombRush's Avatar
I been hearing squeaky or creaking noise from rear wheel area Not sure if it is suspension, will this caused by my volk sf-challenge. Because I didn't do anything to my suspension (spring, coilover,camber). Will this cause this sound?
Old Oct 24, 2006 | 07:17 AM
35bills's Avatar
When are you hearing this noise?
Does it occur when you are driving regularly?
Does it "squeak" when you are going over a bump?
I really don't think it would be your Volks. Check to see if the wheel lugs are tightened to the correct specs.
Good luck,
Bill
Old Oct 24, 2006 | 10:17 AM
BombRush's Avatar
Yes I hear when I drive normally, yes it does squeak when i go over the bump.
Old Oct 25, 2006 | 03:06 AM
jclit's Avatar
Its your suspension. Theres a TSB out for it.
Old Oct 27, 2006 | 07:48 PM
wickedik's Avatar
anyone have the link to this tsb?
Old Nov 20, 2006 | 04:47 PM
speedybc86's Avatar
I have a squealing sound somewhere in rear wheel area. It's only audible when i am turning. Is this the same problem?
Old Nov 20, 2006 | 06:20 PM
BombRush's Avatar
not really. I hear it loud when i go over the speed bumps.
Old Nov 20, 2006 | 07:28 PM
LazerRed1's Avatar
Here is link to TSB's.
http://www.infinitihelp.com/Infiniti/Models/Models.htm
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
BlackGee35
Jul 23, 2015 01:36 PM
Soumilg
Jul 18, 2015 12:33 PM
