Tein Basic and rear camber toe arm enough?
Old Nov 5, 2006 | 05:56 AM
46.5quartermile's Avatar
Im thinking about buying the Tein basic and droping the rear of my 05 g3 coupe at least 2 inches. Do you think a camber toe arm that adjusts up to 3 degrees will be enough to compensate for the negative camber? Also do you think it will be vital to get a front camber kit because those are expensive! Should also mention im on the 19in forged rims.
http://cgi.ebay.com/ebaymotors/350Z-...spagenameZWDVW
Old Nov 5, 2006 | 02:00 PM
GReddySetGO's Avatar
I think it should. I'm dropped on Tein S. Techs, I believe is about an inch drop in the rear, I was off by like 1.0 degrees.
Old Nov 5, 2006 | 03:07 PM
redlude97's Avatar
If you drop 2 inches in the front, you will need a camber kit for sure. For the rear pick up the SPC camber arm/toebolt setup or a camber arm/toe arm setup if you prefer that method
Old Nov 5, 2006 | 03:45 PM
Buy my rear camer arms
https://g35driver.com/forums/archived-sales/122281-fs-camber-toe-arms.html
Old Nov 5, 2006 | 05:23 PM
Will my toe be changed in the rear by a drop? I would think maybe caster but not toe.
Old Nov 5, 2006 | 05:25 PM
redlude97's Avatar
Yes, toe will be affected
rezendvous420
May 31, 2020 01:26 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
beevanhuynh
Jul 23, 2015 01:37 AM
