Stillen Rear Camber Adjuster
Old Nov 12, 2006 | 05:22 PM
k_hojnacki's Avatar
I just finished up my suspension upgrade w/ new Tein CS. EDFC, Stillen rear camber adjusters. Stillen rear toe adjusters and new Cusco A arms. I could not for the life of me get the camber adjusters in. They seemed just too large to fit in the brackets. Anyone seen this issue in the past? I did a search but no luck. Thanks
Old Nov 13, 2006 | 01:17 PM
kenchan's Avatar
im running the rear stillen rods on my 04.5 and they fit fine...
i did the install.
Old Nov 13, 2006 | 01:48 PM
k_hojnacki's Avatar
i did the install.
So your slid right into place? Maybe its a year thing because my 03 they appear to be about 1/16 of an inch too wide. It came to the point I was bending the bracket to fit them in place. At that point I called it quits since I wasn't dropping the backend that much. Thanks for the reply.
Old Nov 13, 2006 | 03:13 PM
kenchan's Avatar
yah, should slide in. well, i tapped it in gently with a small mallet to
get it into position. you were smart to stop. no suspension part needs
that much force to be aligned into place.
Old Nov 17, 2009 | 11:09 AM
JBALLA's Avatar
did you ever fix the problem mine went right in
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
