wheel lean
Old Nov 15, 2006 | 01:00 AM
realgone's Avatar
Widdle ya into kindling
wheel lean
Just put the stocks back on for Winter and noticed that the rear wheels, especially drivers side appear to be leaning slightly in from bottom to top (/0\). They may have been doing this with the Volks as well, but went unnoticed. Also where the wheel touches the hub, you can fit a fingernail.
Is it time for an alignment, is this normal, or should I be concerned about other issues?
Old Nov 15, 2006 | 01:18 AM
GTR_Boy's Avatar
1. Are you sure you torqued down all of the nuts to the proper torque settings?
2. Is your ride lowered?
3. If in doubt, go to a tire shop to ask. Maybe it is time for an alignment?
Old Nov 15, 2006 | 01:32 AM
realgone's Avatar
Not lowered.
My dad changed them for me. He used a torque wrench to torque all the nuts to 85.
When driving away my dad noticed that the wheel appeared to be leaning. I stopped at the local tire shop and they said it looks like it might be an alignment issue.
I wanted to make sure before I take the car in for an alignment or if it was normal.
Old Nov 15, 2006 | 12:28 PM
bull3t's Avatar
our cars have negative camber (/0\). that's why we have inner tire feathering issues...i think it can be fixed with a camber kit...if it's only doing it a little it's
probably normal for our cars...if it's doing it alot it might be due to worn springs...get it checked out by a professional
Old Nov 23, 2006 | 02:44 PM
realgone's Avatar
Is there a reason for the negative camber, or is this a design flaw?
Old Nov 24, 2006 | 01:19 AM
GreenGoblin's Avatar
The goblin resurrection
it is the design the rear has some camber stock
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
