View Poll Results: wat problems r u having?
installed spacers, have ABS, Slip, VDC lights on
29
18.01%
installed spacers, have knocking
4.35%
installed spacers, have both lights and knocking
3.73%
didn't install spacers, have no problem
40
24.84%
didn't install spacers, have one of the problems above
4.35%
didn't install the camber kit yet.
43
26.71%
installed spacers, no problem
29
18.01%
Voters: 161. You may not vote on this poll
SPC Poll
Thats what I thought, from my understanding, the only issue still with the arms is clearance issues in the fenders and the arms actually bottoming out, correct?
Update: I've installed the new arms and wanted to make sure of my results so I apologize for the delay.
I have some good news and some bad news. First the bad, I still have the knocking issue although it's not as frequent and as dramatic. I'm running the G application Swift springs and they have a very soft spring rate (the softest spring rate available for the G) and that's the reason SPC wanted to work with me. With the soft spring rate along with the high velocity bumps the springs allowed for more camber arm upward movement therefore, the knocking issue. SPC felt if they could solve the problem on my car they had the problem solved.
The good news is that for the mass majority the camber kit should work depending on your spring rate. After talking to Ben (CEO) of SPC, the recommendation is for anyone that has a concern is to talk with Peter at IAP and discuss your setup and he can advise you whether your arms would work or you would need to exchange them for the new revised arms at no charge. If the knocking does happen they can supply you with spacers that will get stalled with your bump stop which would definitely solve the problem.
Mark
Mark
I just installed front and rear camber kit yesterday. VDC, SLIP, ABS lights all on. Some knocking sounds when driving. Rolling on Tokico DSP-7 and Tanabe DF210 springs. Please help advise. Thanks in advance.
i will be installing mine on tuesday. will report.
I went with the 350EVO arms although they are pricey, they are excellent. I now have no knocking issue but because they are much lighter, and with the lighter unsprung weight the benefits are better handling, braking, and ride. For the money if you can get the SPC's to work they are a good bang for the buck but they are not in the same class as the EVO's
If you can't get the knocking issue resolved SPC is excellent in backing their product and will work with you and if ultimately you want a refund I'm sure they will acommodate you.
Mark
Too be honest I am not sure if I have the revised version or not. I bought them from THMotorsports this month. I don't really hear knocking when I am driving normally. I hear noises usually on larger bumps on the road. As far as the sensor is concerned. I am not sure what happened because I had a shop install it. They say that the sensor is where it is suppose to me and they used the spacers that came with the kit. They said that I need to go to the dealership to have the computer reset. Is this true or is this something that I can fix myself?
There is no need for the computers to be reset, if you think about it, nothing about the sensor has been changed only the location. The spacers adds 2* degrees of positive camber and the arms adds 1* which gives a total of 3*. If 1* can get back into spec you can go without the spacers although the spacers will give alot more flexability if you change your setup. SPC allowed me to keep their spacers and the 350EVO's get 1* of positive camber although with the spacer, I get a full 3*.
Peter at IAP who his an authorized SPC dealer took care of many of our forum members who bought from him although, I know nothing about THMotorsports. With THMotorsports telling you that the computer has to be reset I'm not to sure how much they know about these arms or they are just trying to pass the buck? If they won't resolve the issues, I would contact SPC directly since they know the problems with these arms and see if they would be willing to help you.
Mark
ooh oh, i think i'm experiancing the knocking, i wasn't aware that the knock was over the large and the high velocity bumps or dips. i thought people were just driving around nomally, and getting knocking noise... i figured i was just too low. i actually raised it up the other day, and still get the knocking. its been 6 months, of driving with them. i wonder if anything can be done..
