View Poll Results: wat problems r u having?
installed spacers, have ABS, Slip, VDC lights on
29
18.01%
installed spacers, have knocking
4.35%
installed spacers, have both lights and knocking
3.73%
didn't install spacers, have no problem
40
24.84%
didn't install spacers, have one of the problems above
4.35%
didn't install the camber kit yet.
43
26.71%
installed spacers, no problem
29
18.01%
Voters: 161. You may not vote on this poll
SPC Poll
Old Nov 21, 2006 | 09:19 AM
Jamaica2G's Avatar
Originally Posted by Gilley
Me too, but mine were prototypes, so I don't know if there are dimensional differences.
Nope, I got a prototype as well Gilley....
Lights & Knocking here... YAY !
Adrian
Old Nov 21, 2006 | 11:38 AM
Gilley's Avatar
Adrian
I guess they are similar then. But I know your car is a lot lower than mine.
Old Nov 21, 2006 | 03:58 PM
mark4x4's Avatar
Anyone who has the SPC front camber kit please vote because the more input we get the better.
Suspension wise I'm as stock as you can get, the only change I've made is the Swift springs which gives me a drop of front: 1" rear: .6" and I have the clunking issue.
I just off the phone with Charley the lead engineer at SPC and he will be looking into this problem. Also, talked to Peter and he knows of this issue and told him I will wait a reasonable amount to time to see if there will be a fix for this problem. If not, I will receive a refund on the camber kit only although I will be out $350 for the installation and the alignment cost. Then another $350 for the install and realignment of either a fixed SPC arms or whatever new arms I get.
Old Nov 21, 2006 | 04:25 PM
Gilley's Avatar
You can do the swap yourself with a few basic tools.
Old Nov 21, 2006 | 04:49 PM
Aznteazer's Avatar
just this past weekend, my mom's rx330 believe it or not got abs, brake, and vsc trac lights on.
lol. at least i got is250 as a loaner to drive around with just 1700 miles on it.
navi is cool but it's so slow. 05 g35 shifts faster in manual mode than is250 imo.
Old Nov 21, 2006 | 08:37 PM
mark4x4's Avatar
For those of you that have arms that are hitting can you give me details such as, the type of sound, when it hits, are you turning or going straight, is it a bump or a pothole or both, the more info the better.
In my case, it's usually on the freeway although maybe about 10% of the times it's around town driving. I've also noticed that it happens more often when both wheels hit bumps together rather than independently, the key word is more often. When the arms hit it makes a loud bang along with a huge vibration. A few times while on the off ramp of a freeway I noticed a brushing sound which I believe to be the arms brushing against the inner fender lining.
In my previous post, I took my car back where I got the camber kit installed and my alignment and he thought it was the top adjustment bolt hitting top of the fender. The odd thing is I'm only dropped 1" and no other aftermarket suspension parts installed.
I'd appreciate if you are this having this problem post your info and maybe we might have a common thread that's causing this problem.
Old Nov 21, 2006 | 08:39 PM
2006_G_coupe's Avatar
I have no problems with spacers because i am stock.!! Stock= 0 problems.!! jmo..
Old Nov 22, 2006 | 09:37 AM
Gilley's Avatar
And looking like eveyone else. Thanks for your help solving this complex problem.
Old Nov 22, 2006 | 04:27 PM
G35BASTARD's Avatar
OK has ANYONE done the installation w/ everything and had NO problems?
Old Nov 23, 2006 | 03:11 AM
richboy's Avatar
MORE POWER PLZ!!!
Man..i thought that knocking noise wouldn't bother me that much but...DAMN its getting annoying now. I hope SPC can fix this problem
Old Nov 24, 2006 | 03:39 PM
G35sedan03's Avatar
I'm getting my SPC control arms installed today at Lokey infiniti. I'll post later on, hopefully will have no issues.
Old Nov 27, 2006 | 04:14 AM
mark4x4's Avatar
I for one will not live with this problem, either the problem gets fixed or I'll request a refund.
Old Nov 27, 2006 | 04:55 AM
cungkpham's Avatar
i recieved my SPC arms 1 month ago, never had the time to install it... wow, sounds poorly made. i would also like to hear updates.
Old Nov 27, 2006 | 11:58 AM
richboy's Avatar
MORE POWER PLZ!!!
So whats up are we all going to return the SPC camber arms back? i contacted 350evo n they have there arms in stock i might order if i can get a refund back
Old Nov 27, 2006 | 05:00 PM
  #30
Aznteazer's Avatar
wow i just heard the FIRST KNOCK TODAY! woohoo. can i change my selection on the poll?
so what's up with the new bracket and all?
can't really take this much longer......
