19x 9front 41mm offset, 19x10 rear 42mm offset. NEED TIRE ADVICE
Old Nov 16, 2006 | 09:35 PM
cconklin1's Avatar
As stated, need some expert info on what to put on the above size wheels for my 2005 coupe. any input is appreciated.
Sizes and pros and cons please list!
Best,
Chris
Old Nov 16, 2006 | 11:52 PM
redlude97's Avatar
I don't even think those offsets will fit, way to sucken in. For those sizes you are looking for high 20 offsets, not 40
Old Nov 17, 2006 | 08:13 AM
lowrider's Avatar
He speaketh the truth.
Lou
Old Nov 17, 2006 | 08:25 AM
SilverII's Avatar
Totally wrong offsets.
Old Nov 17, 2006 | 08:34 AM
cconklin1's Avatar
alright, I am totally confused now. These were recommended to me as being the right offsets for the coupe with this wheel size. Using an offset calculator herehttp://www.1010tires.com/WheelOffsetCalculator.asp
I thought this would work.
Old Nov 17, 2006 | 08:38 AM
GEE35FX's Avatar
But your stock offset for a coupe is 30mm.
Old Nov 17, 2006 | 08:46 AM
cconklin1's Avatar
I know my stock offset is 30mm and the wheel width is 8". Using the above calculator led me to believe that the new wheel would actually stick out 13mm MORE than stock on the rear, and about 2mm more than stock on front. I thought that this would give the proper "stance for the coupe". If this is not the case, what am I doing wrong? I am now very very confused!
Old Nov 17, 2006 | 12:06 PM
absolutg's Avatar
workin...
the offsets are good for a sedan, not coupe
Old Nov 17, 2006 | 12:30 PM
redlude97's Avatar
The problem is not outer wheel clearance, its the inner wheel clearance where you will have issues. With that high of an offset, you are likely to contact suspension components on the inside of the wheel. Thats why I say it won't fit
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
