Brake Swap Brembo coupe to G35 Sedan
Old Nov 21, 2006 | 11:08 PM
sly1types's Avatar
Hey guys I searched this and found nothing, my question is could i just get the factory Brembo brakes from a G35 coupe and bolt right up to a sedan?
Old Nov 21, 2006 | 11:36 PM
g35cas's Avatar
I don't know if this will help, but auto coupes and non-track Z's have the same bolt pattern as the Brembo's. You could ask at the Infiniti parts department, they should be able to bring up the schematic on their computer of both a sedan and coupe brembo to tell you if they are the same.
Good luck.
Old Nov 21, 2006 | 11:39 PM
Klubbheads's Avatar
i think they do bolt right up, PM GurgenPB he has done that on his 03 sedan.
Old Nov 23, 2006 | 04:31 PM
myG35ZX's Avatar
They fit, the sedan wheels do not clear them though.
Old Nov 23, 2006 | 07:47 PM
sly1types's Avatar
So you have done this?
Old Nov 23, 2006 | 08:50 PM
ttrank's Avatar
Grocery getter
Yes they will fit and they should clear the sport wheels. My BBK clears the 04' oem sport wheels.
Old Nov 24, 2006 | 12:17 AM
myG35ZX's Avatar
I had a set of brembos from an 04 coupe. I installed the fronts and my 05 18's did not clear. What BBK do you have - it's not in your sig?
Old Nov 24, 2006 | 12:57 AM
ttrank's Avatar
Grocery getter
Racing Brake 13" 4-pot
Old Nov 24, 2006 | 01:20 AM
GreenGoblin's Avatar
The goblin resurrection
very nice ^
Old Nov 24, 2006 | 10:06 AM
myG35ZX's Avatar
I wonder the size difference between the Racing Brake and OE Brembos? Obviously the Brembos and my 05 brakes are 13", but the Brembos are much wider. They looked fantastic on my OB sedan, but none of my wheels cleared them (summer, winter, track) and I did not want to buy newones. I'll check out your Racing Brake kit. Thanks for the heads up.
Old Nov 24, 2006 | 10:53 AM
ttrank's Avatar
Grocery getter
Brembos are 12.8" 4-pot.
RB has measurements on their site which should help out.
Did you sell the brembos?
Old Nov 24, 2006 | 05:19 PM
myG35ZX's Avatar
Yes I sold them to another member here (maybe my350z, I forget). I really want to upgrade the brakes, but I am not interested in buying all new wheels.
Old May 18, 2011 | 01:00 PM
06infinitig35's Avatar
I don't mean to jack your thread but I've got a pretty much similar fitting question. I've got a 06 g35 coupe and I'm looking to upgrade the calipers on it to the brembo ones. Their not that easy to come by but I did come across a shop that's selling 2 front and 2 rear brembo calipers off an 06 subaru STI. I was wondering if anyone knows if they fit. I'm running with the OEM 19" stagared infiniti RAYS rims. I don't know if they clear either. Thanks in advance
Old May 18, 2011 | 01:16 PM
S 854's Avatar
^ Don't think anyone would accuse you of threadjacking a 4+ year old thread.
Never knew that Subaru STI brembo's bolt straight up to the first gen G35's. I'd imagine that they would fit assuming they are of similar if not exact dimensions as the g35/350z brembo's. Are you sure they bolt up to the G35?
Only way to know for sure is to do an actual test fit behind your 19" OEM's. Those coupe Ray's do clear alot of BBK tho from seeing various setups around here.
Old May 18, 2011 | 01:26 PM
G35SedanGrn's Avatar
just wondering would my coupe 18's on my sedan clear oem brembo's??
