Help me choose shocks!
Old Dec 6, 2006 | 04:28 PM
RetardGarage's Avatar
03 G35C 6MT, has Tein 350Z springs, but OEM shocks. I can tell they're nearing the end of their useful life, and would like some feedback on your experiences with similar setups...
Not looking for adjustability, nor am I looking to drop a ton of $... Just need proper dampening for a lowered G.
Thanks!
Old Dec 6, 2006 | 04:43 PM
redlude97's Avatar
d-specs or koni yellows are the best options available, or pick up some OEM sport suspension shocks from a low mileage coupe or revised 350z shocks
Old Dec 6, 2006 | 04:49 PM
Nismo G's Avatar
whats the difference between coilovers and shocks??? Dont coilovers just come with the springs as well?? And the shock is just..well the shock. SO if i were to order tein springs and then a set of shocks i would basicly have coilovers?
Old Dec 6, 2006 | 05:33 PM
dklau33's Avatar
In a sense yes, you would have coilovers being that the coil springs are over the shocks. But what the aftermarket coilovers today usually are associated with is the ability for ride height adjustability (sometimes separate from spring preload) and damping adjustability. They usually also come with spring rates that are significantly higher than stock as well.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
TheBay
Sep 3, 2015 03:27 PM
