tire pressure light on??
Old Dec 8, 2006 | 12:15 AM
pissout's Avatar
I have spring,shocks and camber kit front and rear yesterday
Tire air pressure light came on today..
Can anyone tell me what to do??
Old Dec 8, 2006 | 12:17 AM
BayAreaRefuGz's Avatar
i fly low
check your tire PSI. my light went on the other day. as soon as i saw the light, i checked all the tire's psi. they were all at 30 psi. just make it 35+ and it'll turn right off
Old Dec 8, 2006 | 12:36 AM
pissout's Avatar
thanks for the info.. by the way , what is "PSI"?
Old Dec 8, 2006 | 12:39 AM
i fly low
not sure what it stands for exactly
but anyway..look around the tire (rubber) for "max load psi"
if you have OEM rims (stock) it should max out at 51 psi
when you pump your tires, pump it for a split second to see where the psi meter landed. the continue on until you hit 35-40 psi
Old Dec 8, 2006 | 12:42 AM
realgone's Avatar
Widdle ya into kindling
It is probably from the cold weather. Mine keeps going off, but I have left the tires alone. I think it is better to run them softer in the cold weather, for a somewhat better traction.
Old Dec 8, 2006 | 12:46 AM
pissout's Avatar
My rims r VOLK 19' sf challenge... still hit 35-40 psi??
thanks
Old Dec 8, 2006 | 12:50 AM
i fly low
it depends on your tire, what rubber are you using?
Old Dec 8, 2006 | 08:20 AM
v8hunter's Avatar
it stands for pounds per square inch
Old Dec 8, 2006 | 08:34 AM
Lords47's Avatar
Also, if you have aftermarket rims on the car, that will make it go off too. There's a tire pressure monitor on the stock wheel, so if that's removed, on a longer drive, it will trigger the sensor to go off. Happens to me all the time. Turn off the car and start it up again, the light will be off.
Old Dec 11, 2006 | 11:07 AM
SFG356MT's Avatar
When you go with aftermarket rims without installing your TPMS the light will go off after about 40 miles of driving. My car does it and I check with the Infiniti shop to confirm. You'll notice that without the sensors the system doesnt' beep it just lights up.
Old Dec 12, 2006 | 12:55 AM
G THANG's Avatar
Yeah that happens to me also,if the car sits overnite in the cold it comes on.
Old Dec 12, 2006 | 10:41 AM
ch1townballa's Avatar
yea my tire pressure thing has been on for a couple days mainly cuz of the cold weather, i checked the PSI and they were all around 35 and when i put in a little more air it tends to turn off and then go on again the next morning
Old Dec 20, 2006 | 08:14 PM
bostoncal's Avatar
yea, i get tons of call about tire pressure sensor going off during the cold weather which is normal. after 20-30 min of driving, the light should go away unless you have a slow leak.
jsimonk
Dec 22, 2023 03:49 PM
Fireman07603
Aug 9, 2015 06:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
