Sways keep lossing a nut
Old Dec 10, 2006 | 02:40 AM
glennp_1999's Avatar
I had my sways for more than 2 years and have lost a total of 4 nuts on the right side of my front sway. Everytime I keep on replacing the nut on the end link, but it still comes loose and eventually falls off. Now my latest dilema is that my whole front end sway has come loose. My front end feels like it's going to fall off and I get a bad vibration even at low speeds. This thing blows I'll be putting my original sways back on so I don't have to deal with this crap anymore. Sorry had to vent.
Old Dec 10, 2006 | 03:08 AM
Hraesvelg's Avatar
it's much better to bust a nut than lose one.
Old Dec 10, 2006 | 03:09 AM
5150DS's Avatar
^lol
Did you try loctite or anything like that.
Old Dec 10, 2006 | 09:13 PM
GreenGoblin's Avatar
The goblin resurrection
why not install a cotter pin?
Old Dec 10, 2006 | 09:51 PM
Sponger's Avatar
6MT Brembo Coupe
Originally Posted by 5150DS
^lol
+1...Loctite will do the trick. Just make sure you don't use the one made for engine assembly (rods) or it will be a PITA to get the nuts off when you need to.
Old Dec 11, 2006 | 01:54 AM
Yep put all kinds of loctite on it and still comes off.
Old Dec 11, 2006 | 01:55 AM
LOL! How true!
Old Dec 11, 2006 | 09:03 AM
TINMAN's Avatar
try loctite in combination with lock washer....if there's room on the thread,use another nut right on top of that nut and if you can,drill a small hole on the outside to use the cotter pin
if after all that and it still come loose? throw that POS in da trash
Old Dec 11, 2006 | 10:42 AM
SFG356MT's Avatar
^+1 if the solution up above doesn't work then weld it
Old Dec 11, 2006 | 01:08 PM
badtziscool's Avatar
Raise up off these N.U.Ts
Cuz you gets none of deez.
At ease.
Old Dec 11, 2006 | 02:53 PM
dklau33's Avatar
Have you tried replacing the end link as well?
Old Dec 11, 2006 | 05:15 PM
Nothing wrong with the end link. I can do what Tinman said but I don't want to go through all that trouble since I'm selling the car anyways. So I'll have my friend take the damn thing out and just put the originals back on. When I take out the sways I'll sell it on here and just inform the buyer of what he or she needs to do. Screw it.
Old Dec 11, 2006 | 06:40 PM
DHCrocks's Avatar
loctite blue should hold, if that doesn't use red. If the thread are all messed up from coming off and the rod end rubbing on the threads you might need to use a thread chaser the recut the threads, then the loctite should hold.
Old Dec 11, 2006 | 07:13 PM
bull3t's Avatar
what brand sways do you have?
Old Dec 11, 2006 | 07:27 PM
Hotchkis sways and yes it's adjustable. If I ever do sell it I'll let you guys know.
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
