just quick question...
Old Dec 9, 2006 | 06:59 PM
pissout's Avatar
I installed kinetix front arm and spc rear arm (without spc toe thing)
1. Should I replace front camber arm or just leave it?? (hitting the inside frame of car.)
If so, which brand should I get??
2. I only installed spc rear arm.. Is it still safe without spc toe bolt??
plz help....
Old Dec 12, 2006 | 12:19 PM
Gsedan35's Avatar
I've never heard of someone having issues with the Kinetix front camber arms hitting the inside frame. Is the problem related to how low you've dropped the car? In which case you'd want to either raise the car or locate a front arm system that has a lower profile at the top.
The catch about only doing a rear camber arm and nothing about toe is this. As you remove higher and higher amounts of negitive camber you induce changes to toe that the oem system can only remove so much of. You may find that you run out of toe adjustment before you get the rear camber where you want.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Jcruzg35
Sep 26, 2015 04:47 PM
mattdg35
Sep 14, 2015 11:28 AM
