Brake Squeeking Even After Replacing Brake Pad
Old Dec 17, 2006 | 01:29 PM
tgicedsoul's Avatar
Exclamation Brake Squeeking Even After Replacing Brake Pad
Hi Everyone,
My brake start squeeking at low speed just before coming to a stop couple of weeks ago.
I replaced my brake pad just today but the situation got worse imo.
I don't know what is wrong with my brake system.
I have Brembo option w/ 26K miles on them.
PLZ, any advice/idea/suggestion are welcome.
Thanks!!
Old Dec 17, 2006 | 02:40 PM
SuperShick's Avatar
what kinda pads? need that piece of info
Old Dec 17, 2006 | 02:52 PM
g35cas's Avatar
Did you put brake quiet or some other synthetic lube on the back of the pads?
Old Dec 17, 2006 | 03:07 PM
tgicedsoul's Avatar
I replaced both front and back with HAWK HPS
& No, i didn't put the brake quiet or synthetic lube on the back of the pads.
Is this because the pads are brand new??
Also, the car doesn't feel right while rolling to a stop in netrual.
It feels like at the very end before it stops the brake is working.
I did have a hard time pushing the front brake pads back into the caliper while installing them.
Thanks!!
Old Dec 17, 2006 | 04:16 PM
fortified's Avatar
Coating the backside of the pads helps, as well as making sure the guides allow free movement.
Excess noise can be related to poor pad/rotor interface also, due to deposits, poor bedding, etc.
Old Dec 18, 2006 | 07:52 AM
tgicedsoul's Avatar
I guess i'll have fine another time to re-install those pads??
What brand of the brake quiet will you guys recommand?
Thanks!!
Old Dec 18, 2006 | 10:37 AM
fortified's Avatar
http://ken-co.com/castle/qt.htm
Old Dec 18, 2006 | 11:31 PM
tgicedsoul's Avatar
Thanks!!
I just want to ask everyone who has HWAK HPS pad w/ brembo caliper.
Does anyone else had a hard time pushing the pads back into the caliper??
Or it's just mine ??
Old Dec 18, 2006 | 11:36 PM
Og_Dave's Avatar
i believe Urban here has those Hawk pads on stock calipers but with Race pads, there going to squeak..... they only work when breaking hard and such and when your using them 110%
the stock pads dont squeak hah get some of those if you cant stand the squeaking
Old Dec 18, 2006 | 11:43 PM
filanj's Avatar
Originally Posted by tgicedsoul
Thanks!!
yes, it is verrry tricky... you have to squeeze the pistons in and then quickly put the put in place. a rubber mallet is very helpful
Old Dec 18, 2006 | 11:48 PM
plaing35coupe's Avatar
Sneaker Whore
Wait at least 1k and see if they still squeek after that. If they don't go back to the dealership. I just got my replaced and had the same problem. Its over 1k miles now and no squeeky sounds.
Old Dec 19, 2006 | 12:11 AM
tgicedsoul's Avatar
Thanks for everyone's input so far
There was this strange feeling i mentioned in the previous thread before.
When the car is rolling to a stop in neutral, it feels the brake is working -_-"
It has this "stop w/ brake" feeling right before the car comes to a stop.
Do you guys know what might be causing this?
It's hard for me not to relate it to the brake pad replacment.
'cause it start occuring after raplacing the brake pads.
Thanks!!
Old Dec 21, 2006 | 09:54 PM
FLAG35's Avatar
try a slight chamfer at top of pads
i replaced my front pads (04 6MT sedan w/o brembos)with Hawk HPS last weekend. i had a hard time getting the caliper back on because of the lip at the top edge of the rotors from the wear. so i just gently put about a 32nd inch chamfer at the top of the pads where they contact the top of the rotor using a grinder. worked like a charm. your pads may be not making good contact with the rotors and thus giving you the "rubbing" feel you describe and also causing the squeeling.
i also used the lube on the back of the pads and followed Hawk's recommended break-in. so far pads seem fine and no noise.
Old Dec 23, 2006 | 03:54 PM
Q45tech's Avatar
Everytime you replace pads you must measure the rotor runout and shim to perfection [0.000" runout].
Amazon Amazon
http://www.brakealign.com/pdfs/instructionsforuse.pdf
http://www.brakealign.com/pdfs/othersappchart.pdf
http://lyberty.com/car/Maxima_A32_do.../NTB00-033.pdf
above shows how to measure
Lot's more to quiet stopping than a pad slap.
jsimonk
Dec 22, 2023 03:49 PM
Frankieg35
Mar 20, 2016 09:42 PM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
