Review: Nismo S-tune Suspension for JDM Skyline Coupe
Old Mar 24, 2007 | 01:52 AM
jonnylaw's Avatar
I wonder what the difference is b/w the 05 sport suspension and the g-attack--anyone know the difference in firmness/spring rates?
Old Mar 24, 2007 | 02:02 AM
GTR_Boy's Avatar
Originally Posted by bwassul
The Nismo sways have the same stiffness as the sport-tuned suspension sways, but I see you have an '03. I went with some Hotchkis sways simply because I had the sport-tuned ones and wanted more roll stiffness. The Nismo ones should be fine...coupled with the suspension, you'd have a Nismo-tuned ride. I don't think the Nismo sways will give you many problems with the end links since they're so close to the ones you have. If I remember, the Nismo sways are fairly expensive. The ones from Stillen give you a little more stiffness and are very popular. I have the Hotchkis and can't complain.
275 T1Rs on 10.5" rims at +22 is a very common setup. I can go into the parking lot here at work and find at least two G's like that . You'd get problems only if your car was really slammed, but the S-tune only lowers 0.8".
Thanks bwassul for your helpful info. Yeah, I'm not looking for anything to significantly lower the height, but rather to improve handling while not sacrificing too much in ride comfort, nor worrying too much about needing to fix camber. This is my daily driver, so ride comfort must be tolerable. I don't really track the car, but would enjoy some spirited driving on weekends carving up the twisties. Would the sway bars make a significant improvement over my stock ones? I've never had aftermarket sway bars on any of my cars before. Always thought most of the handling was in the shock/spring combo.
Hmmm, just wondering if there's a place with good pricing for the Nismo S-Tune suspension?
Old Mar 24, 2007 | 03:02 PM
bwassul's Avatar
'05 sport suspension is 5kg/mm front, 6kg/mm back
g-attack is 8kg/mm front, 9kg/mm back
The g-attack is firmer than stock but not dramatically so. I'd consider a very good all-around suspension, although if you're looking for a soft, cushy ride it isn't for you.
bwassul's Avatar
The only place I could even find it was japanparts.com
Old Mar 27, 2007 | 01:29 AM
GTR_Boy's Avatar
Thanks. BTW, do you still have your alignment datasheet to post up?
Old Mar 27, 2007 | 01:41 AM
jonnylaw's Avatar
Rhdjapan.com also has the s-tune suspension for the cpv35/v35/z33 and its on sale: https://www.rhdjapan.com/home/produc...roduct_id=1475
Old Oct 8, 2012 | 06:12 AM
n15m0's Avatar
Sorry to bring up an ancient thread but just wanted some confirmation as I have access to a 350z s tune for quite a reasonable price.
So question: I'm already dropped on factory z suspension on my sedan. Using the 350z s tune which drops the z by 20mm, I can expect a further 20mm drop on my sedan? Is that a valid assumption?
Thanks
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
yoyoyo8
Aug 12, 2015 03:04 AM
Karnicle
Jul 23, 2015 05:08 AM
Kz_Ed
Jul 23, 2015 02:41 AM
