350z Sway Bar Question
I've done a lot of searching but I can't seem to find an answer. I finally have a full z unrevised suspension and a set of revised coupe springs to play around and swap with. So onto to my question....
Can you use 350z sways on an '04 Sedan 6mt? If so is there a benefit over the stock G sedan setup and are there any differences/revisions in the years. I remember reading somewhere that the newer 6mt sedan has the same size bar as mine, but the walls were thicker, thus improving hadling.
Your thoughts....
Thanks in advance
Your thoughts....
Thanks in advance
Full Z unrevised suspension as in unrevised shocks?
Oem 03-04 Z sway's are the same exact parts that your 04 sedan has now. A 04.5+ Z with the revised suspension will have a 17% stiffer front bar. As with anything, you'd need to weigh the cost to get one into your garage vs the cost of getting a aftermarket front and rear adjustable bar set into your garage. Most go with the latter.
DO NOT use the unrevised Z shocks unless the roads you drive on are perfect. I had them on for about a year and although they handled great for a stock shock at the track, the everday driving bounce and the highway porpoising was annoying. There's a reason why Nissan revised the shocks.
Originally Posted by az1anbeethoven
^+1...the unrevised shocks are junk...might as well use your oem ones...
Well I have no data to suggest that the rear oem sway's of any make or model of G or Z are any different from 03 to 06. So, will $85 shipped for a 17% stiffer front bar mesh with your plans on enhancing the car. I support front roll stiffness increases from my own testing. However, for $125 plus shipping one can buy a Progress front bar that is adjustable.
Unrevised oem Z shocks will bless your car with the same bounce and porposing issues that have been the bane of 03/04 Z owners. The shocks have a very high level of compression dampning which makes them feel like they are ready to rock. Problem is, once you encounter real world bumps the shocks lack of rebound control ruins any they have. This mean's corners had better be smooth as glass, otherwise the bounce is so bad you cannot carry speed as ultimate adheasion bounces away. I had a 03 Z suspension on my car at first, so I'm speaking from direct experience. Performance with Cusco Sway's was really nice, but that was when the pavement was smooth. I got tired of the bounce and porposing and sold the oem Z parts.
I'll probably pass on the sways and get something aftermarket.
rezendvous420
May 31, 2020 01:26 PM
