Questions on suspension setup
Dec 30, 2006 | 02:39 PM
I am running oem 19s with 245/35 and 255/40 in the rear, I've heard that closer width front and rear will decrease some undeersteer. Car does seem a little more tail happy with this setup.
Anyways, I hate the gap between the fenders with oem 19s and I just bought tires so I want to run them at lest a year before buying new wheels. That being said I'm thinking of just getting Ichiba 25mm spacers in the rear and leaving the front normal. I don't think the front is too bad also I want to be cheap since I really do plan on getting new wheels later.
Is it bad to just run spacers in the rear, I mean 25mm is almost an inch too so to me it seems I'm really starting to mess up my suspension setup. I mean the difference in width of tires is one thing and now I'd have the rear sitting almost 2 inchs wider than the front.
Also I plan on ordering a Hotchkis sway bar set. What do you guys think of what will be happening to my suspension.
I take corners hard a lot, will wheel spacers run the potential of breaking studs since all the weight of the wheels are on the studs?
Thanks
Reply 0
Dec 30, 2006 | 02:52 PM
Your suspension...............
Installing the sways will decrease the body roll or at least it did with the
Stillen sways I have. I don't know what to tell you about using spacers
because I'm not in favor of using them.....at all!! Lowering a G is one thing
if you can maintain factory settings but messing with the geometry of the
car isn't advisable.......not to me!
Reply 0
