Newbie here - Tire Sensor question
yes. for multipiece wheels youll need to play with them though. f1 offered to drill into my 3pc wheels to make them fit. i said hell no. you can also use bands.
screw tps...not necessary imo
I didn't put them on mine although they did fit onto my Volks. Reason is that I'm running on 30 series, so there's not much room for a heavy impact such as a pothole. It will likely get damaged if it so happened I hit a pothole right where the sensor is located.
^^If you had your TPS already programmed to your car and it was a simple screw in installation, you should of put them in. I rather risk breaking a TPS than driving on a flat. I got a buddy who now needs to replace 2 tires since he didn't realize his tires were flat and drove a few miles. He went with aftermarket wheels the same time I did but decided not to band in TPS in. Tires aren't cheap at $200-300 a pop. He's just glad the rims aren't damaged.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
