Need Help with Brakes
Old Jan 9, 2007 | 01:33 PM
Floyds_racing's Avatar
I installed new brake pads and rotors about 2000 miles ago and today on my way back from lunch my buddy in his 350z pulled up to run me. We took off I had to step on the brake a few times to keep from rear ending him. I barely pushed it down just enough to slow me down and now my brakes feel like there is nothing there. I pulled in to work I was going maybe 5 MPH and I had to put the pedal to the floor to stop.. WHY?
Tyson
__________________
Old Jan 9, 2007 | 03:54 PM
fortified's Avatar
Your brakes are not bedded in most likely. I had my 04 front rotors and pads replaced under warranty. About 15 minutes after I drove away some idiot charged out of a driveway, when I hit the brakes (only traveling about 35) and I though I was on slick ice! They did eventually slow me down enough to avoid him.
On an empty stretch of highway or country road: Be careful!!
Make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph. Do not allow the vehicle to come to a complete stop. Allow brakes to cool a couple of hours leaving off the emergency brake, before you drive again.
If you installed after-market brakes follow the mfrs recommendations, otherwise the above should work. If none of this helps you, I would make it back to the mechanic ASAP.. and very carefully!
Old Jan 9, 2007 | 07:08 PM
i left work today and they were fine!!!
Old Jan 9, 2007 | 08:05 PM
fortified's Avatar
As they wear in normally they should be. Hopefully it's not an intermittent problem.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
