To those who have Tien Basics...
Old Jan 11, 2007 | 12:36 AM
shortylow50's Avatar
I know you can adjust the height of your drop with Tien basics, but how hard is it to do it? and how do you do it....is it with a controller or do you manually have to do it yourself?
Old Jan 11, 2007 | 12:50 AM
minh420's Avatar
tein basics
if they are brand new they are not too bad to adjust. But if they been on your car for a good while good luck!! I adjusted mine after about 10,000 miles i broke two of the tools they give you to spin the the coil over. i used a breaker bar on the end of the tool to get more leverage. it took a good 3 hours to get every side the right height and even.
Old Jan 11, 2007 | 02:08 AM
oh man... but is it easy in terms of instructions? do u have to take the car apart in anyway or can u just do it in your driveway and do wutever u have to do
Old Jan 11, 2007 | 03:11 AM
redlude97's Avatar
Its pretty much a problem with all coilovers, the threads tend to corrode and stick. Best option likely is to lube them frequently.
Old Jan 11, 2007 | 02:28 PM
GReddySetGO's Avatar
You have to adjust the height manually.
I've never really had a problem with them getting stuck, even after they've been on the car. You can spray WD40 on the threads to help loosen them. The first couple turns are the hardest then it moves pretty easy, unless you are putting more tention on the spring, then its still going to be hard.
Old Jan 11, 2007 | 04:13 PM
Mark350GT's Avatar
its all manual like most coilovers
Old Jan 11, 2007 | 04:17 PM
FL-G35's Avatar
I have lowered and raised my car a few times. Everytime it was in my garage and took maybe an hour to two hours to do. They do get stuck, and once you loosen it it can be a pita turn them.
Old Oct 17, 2009 | 05:43 AM
TwilightBLUES's Avatar
which tool exactly do i need to do this? should it have came with my suspension and what does it look like? help por favor!!!!!!
Old Oct 18, 2009 | 04:46 AM
Ig35's Avatar
this is the tool that should come with tein coilovers.
http://d5otzd52uv6zz.cloudfront.net/...d7eaa8-420.jpg
Old Nov 12, 2009 | 12:43 AM
racertech's Avatar
are the rear wrenches different???
Old Nov 15, 2009 | 04:06 PM
racertech's Avatar
How do u adjust the rear coilovers if the tool for the front is a different size smaller
EPG35
Aug 16, 2015 04:52 PM
OC 350GTCoupe
Aug 11, 2008 09:18 PM
Nismo G
Archived Sales
38
Sep 27, 2007 09:14 PM
Captain Baller
Aug 11, 2006 04:37 PM
ONEmike
May 13, 2005 06:17 PM
