Brembo Brake Question, I Need Help Swap Over Question Please Give Me Your Input?
Old Jan 16, 2007 | 10:36 PM
mwarsh1's Avatar
I Have An 05 G35 Coupe, As Many Of You Know My Year Does Not Come With Brembos, So Ive Been Looking For Somone Selling There Used Oem Kit. I Found A Guy Who Owns A G35 And Is A Mechanic, So He Was Selling His Brembos, Plus The Brembo Rotors-cross Drilled. And He Said He Would Do The Install For Me, What Do You Think Is A Fair Price For All This?
Old Jan 16, 2007 | 11:02 PM
RANDY350Z's Avatar
Brakes alone new are worth 4000.00, how much is he selling it for?
Old Jan 16, 2007 | 11:57 PM
mwarsh1's Avatar
Theese Brakes Are Not New Theey Have 4000 Miles On The Rotors, And Front Pad Need To Be Replaced. Back Pad Are Fine.
Old Jan 17, 2007 | 03:13 AM
redlude97's Avatar
Including install, $1500-$2000 is about right depending on condition etc.
Old Jan 17, 2007 | 03:15 AM
speedracerg35's Avatar
^ this sounds right with or without the install.
Old Jan 17, 2007 | 03:46 AM
Jee_35's Avatar
I would think about 1600 for the brakes, maybe a lil more since he has cross/drilled rotors? which are aftermarket, with install, I would say about 2000 sounds about right.?
Old Jan 17, 2007 | 09:46 AM
duke300zxtt's Avatar
I miss my brembos,I used to have 03 6mt but now I got 06 auto .
Old Jan 17, 2007 | 11:38 AM
mwarsh1's Avatar
Any One Else Have Opinion's?
Old Jan 17, 2007 | 02:45 PM
636Racer's Avatar
$1600 would be a good offer.
Old Jan 18, 2007 | 09:32 PM
mwarsh1's Avatar
Anyone Else?
Old Jan 19, 2007 | 02:14 PM
dklau33's Avatar
on the classifieds over here and my350z a full set of used OE brembos usually go for anywhere from around $1300 - $2000 depending on condition and what's included. a full brake job like that including bleeding all four corners is probably about a 3 hour job. shop rates are usually somewhere in the $75/hour range.
Old Jan 19, 2007 | 02:34 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
That's not a 3 hour job to change all 4 corners. You're just removing the whole brake system and putting on the Brembos. If you had to turn the rotors, then it would take longer. Replacing all 4 corners and bleeding the brakes wouldnt take more than 2 hours at the most, if the guy knew what he was doing.
I'd say $2000 for a front and rear OEM Brembo system plus install is a fair price.
-GP-
Old Jan 19, 2007 | 03:07 PM
RBull's Avatar
Rated M
You may as well change the flex hoses to braided lines at the same time.
Old Jan 19, 2007 | 03:09 PM
Nismo G's Avatar
Doesnt the 05 come with bigger brakes anyways...they are almost equal to the stopping power of the brembos. I guess what im trying to say is that the OEM 2005 brakes are larger than the OEM 2003 non brembo brakes right?
-sean
Old Jan 19, 2007 | 03:11 PM
-sean
I'm pretty sure they're almost the same size rotor. The 05+ might be .5" bigger in diameter. But you can beat the look of the Brembo brakes. I think that's the reason most people do the swap.
-GP-
