Rotor Question
Old Jan 18, 2007 | 07:05 PM
bluestacy04's Avatar
Rotor Question
How heavy are the stock rotors? I tried searching with out any luck.
Old Jan 18, 2007 | 07:33 PM
filanj's Avatar
brembo or non brembo
Old Jan 18, 2007 | 07:38 PM
filanj's Avatar
either way I wouldn't expect them to weigh more than ~30 lbs?
Old Jan 19, 2007 | 01:20 PM
Q45tech's Avatar
A 28mm x 11.08" Q45 rotor weighs less than 20 pounds ~~19lbs...........G35 had various stock rotors depending on year and Brembo.
Fronts usually weigh 40-50% more than rears.
Rotor weight is critical and the heavier the better in most cases, as a 10% increase in weight will lower [spread] the heat rise from braking by 10%.
Easy to calculate the heat rise of rotors if you know car weight and stopping time............and rotor weight.
Old Jan 19, 2007 | 01:40 PM
RacingBrake's Avatar
G35 Brembo (03-04)
Front: 21.1 lbs (324x30mm)
Rear: 17.5 (322x22mm)
G35 non-Brembo (03-04)
Front: 15.3 lbs. (296x24mm)
Rear: 11.3 lbs. (292x16mm)
Old Jan 22, 2007 | 07:45 PM
HotShot's Avatar
Got them on!
I weighed all four rotors when they arrived 61.5 lbs. OEM rotors weighed 56.5 lbs a 5 lb difference. Thought the drilled slotted rotors would weigh less to my surprise that was not the case. So far I am pleased with look and fit, and quality. There is a better braking feel and the pads they provided appear to be low dust (no black wheels) and quiet at this point. Will keep you updated after a few more months of driving.
jsimonk
Dec 22, 2023 03:49 PM
Jiggerjuice
Aug 26, 2015 09:00 AM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RedBaronK
Jul 27, 2015 03:19 PM
