ALIGNMENT RESULTS! How are these.
Old Feb 1, 2007 | 04:18 PM
GThIrtYFiZle's Avatar
Got my alignment done today. I took a pic of the print out but cant find my USB Cord, so here they go:
Front Camber:
L -1.3 R -2.0
Caster:
L 8.3 R 8.9
Toe:
L 0.06 R 0.05
Rear Camber:
L -1.6 R -2.1
Toe:
L 0.10 R 0.09
Do these sound normal? Is this close enough to stock to not be able to notice any great amounts of tire wear? The place I got it done from told me this was not good, meanwhile I went to a more reputable shop (TNR Racing) and the guy told me this is actually pretty good considering the car is dropped and that I could never get it back to perfect since the car was dropped. What do you guys think? TIA.
Old Feb 1, 2007 | 04:22 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The front and rear cross camber is definitely NOT good. That -2.0 camber on the right front and 2.1 on the right rear is going to cause a good amount of uneven edge wear. I'd recommend getting front and rear camber kits.
That's definiely not normal for 350Z H-techs. I have 4 coupes that i do alignments on, they all have H-techs and all have similar specs.
Front Camber:
L -1.5 R -1.6
Toe:
L 0.05 R 0.04
Rear Camber:
L -1.6 R -1.7
Toe:
L 0.11 R 0.10
Old Feb 1, 2007 | 04:38 PM
What can be the problem. Is that .4 degrees going to make that much of a difference? Also, should I try to get my alignment done somewhere else or what?
Old Feb 1, 2007 | 04:45 PM
its not so much the rear as the front cross camber. I'm surprised the car isnt pulling with the -0.7 cross camber. It might just be that the springs havent settled fully, how long did you wait after installing the springs before doing the alignment??
THey should have been able to atleast get the right rear camber down to around -1.7.
-GP-
Old Feb 1, 2007 | 04:50 PM
O HELLA JDM's Avatar
yo grant...is there more tire wear when i get h-techs...
Old Feb 1, 2007 | 04:51 PM
Jeff92se's Avatar
Red Card Crew
Did you go to some chain alignment place? Or a good chassis shop? I would think a good shop could jiggle things around by loosening/tightening some suspension pieces to get another .25 degree of camber back on both the right front / rear. There's always some little things you can adjust to fudge the specs around.
Old Feb 1, 2007 | 04:52 PM
On the front, no matter how much you loosen and fiddle around with the suspension on the front you arent going to get much play in the alignment. On the rear however, they should have definitely been able to get more positive camber for him.
-GP-
Old Feb 1, 2007 | 04:54 PM
any lowering springs are you going give you increased inner edge wear over stock but with the H-techs will be minimal. It's when you drop it more than an inch that you start to get bad inner tire wear... like on my car where my front camber is at -2.3/2.4... the outside of the tire doesnt even touch the road unless i'm taking a hard turn.
-GP-
Old Feb 1, 2007 | 04:57 PM
Jeff92se's Avatar
Red Card Crew
I wonder if the right side is sitting lower thus making the camber out of whack? Would rotating the springs in the perch do anything to raise it just a tad (if that were the case)?
-GP-
Old Feb 1, 2007 | 05:18 PM
redlude97's Avatar
wouldn't the camber even out more once the driver sits in the car, since he sits on the left side?
Old Feb 1, 2007 | 05:48 PM
Sedan, I waited about 2.5 weeks before I got it aligned. I think they are fully settled by now. With this type of camber, how long do you guys think I could keep a set of wheels. How long about will they last. The car is leased, and I am definitely getting the new coupe in 09. Is it worth getting the camber kits? About how many miles can i get to each tire, and should I go back to the place and ask him to do something abou the rear or what? Oh, and yeah, I also have 20 inch rims that i put on during spring time with 245/275. 8.5/10.
Will these cause more wear or would I be able to get through most of my lease by switching rims and tires. Thanx guys, sorry for all the questions, just trying toi see whats best right now.
Old Feb 1, 2007 | 05:49 PM
By the way, like many have said, the right side does sit a bit lower than the left, but from what I have noticed it is not much at all, not visible, meanwhile others have said you can see the difference.
Old Feb 1, 2007 | 09:22 PM
Can anyone else help with this matter please.
Old Feb 1, 2007 | 11:23 PM
MEECHIN's Avatar
It's really simple.
You're gonna have to invest in a set of camber kits for the fronts and rears.
No way around it.
Quite honestly, i worry more about toe than camber.
Moreso the combination of the two.
Negative camber PLUS aggressive toe will destroy tire life.
Minimizing the TOE angle will lengthen tire life.
But as for me, i love running -1.5 in the front and -1.0 in the rear.
TOE being damn near zero of course.
But that's just me.
Good luck.
(spend the cash bub)
Old Feb 2, 2007 | 01:06 AM
Originally Posted by MEECHIN
It's really simple.
No way around it.
But that's just me.
Good luck.
Its not about spending cash or not. I invested into these springs thinking I wouldnt have to do anything else, and since my car is leased, I didnt want to do anything else besides give it a little drop too go good with my rims. Even if tire wear was going to be a bit worse I didnt care cuz I had two sets of wheels and tires and if I had to buy one more set of tires I wouldnt have had a problem. I just dont want to put stuff on the car that I will have to take off later on when I return, since I will be getting the 08. I am not saying that I dont care about money but for you to tell me to spend the cash is not quite right. I have spent a lot more than what the camber kits cost, its the simple fact that I will not be keeping the car, so if I could go another year or so with these why not, since the stock rims and tires are coming off soon. I just wanted to know how long a set of tires would last under these conditions. Thats all. But Thank you anyway bub.
