Does 14" 355mm rotor fit stock brembo caliper?
Old Feb 17, 2007 | 08:20 PM
jd2k1's Avatar
Does 14" 355mm Brembo rotor fit our stock Brembo caliper? Or do I need to replace the caliper to make it fit?
Old Feb 19, 2007 | 05:47 AM
imalazeeass's Avatar
my guess is....... no
Old Feb 19, 2007 | 09:06 AM
Alan's Avatar
mayyyyybe you can have a custom made bracket but even then i highly doubt itll work properly.
Old Feb 20, 2007 | 02:12 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
You can't fit a 14" rotor without changing other components. Think about it, the caliper is fixed, but you're trying to increase rotor diameter?
If you want a larger rotor, you'll need a caliper relocation bracket. There was someone on this forum making them for the G35s, but you had to use a 15.2" rotor.
I was running 314mm (12.36") rotors on my front, now I'm using 345mm (13.6") rotors in the front. But I had to make a pair of brackets.
Most 14" rotors are 32mm thick. The stock brembos are 30mm thick, so you'll also have to consider that.
Unless you're really familiar with the brakes, you're going to find it more trouble than you've anticipated.
Old Feb 21, 2007 | 05:23 AM
jd2k1's Avatar
Thanks for that info E_K.
Was just wondering about the fitment because Stoptech ST40 4pot caliper can accommodate both of their 355mm and 332mm rotors. But then again both of their rotors are 32mm in thickness.
Old Feb 21, 2007 | 05:26 AM
Nismo G's Avatar
i know that stock mustangs can upgrade their rotors to a bigger size...thats the 06 GT though. I doubt a 14 inch rotor will fit the brembos though...
-sean
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
