VDC kicks in too early
Old Feb 23, 2007 | 10:50 PM
coolb's Avatar
I currently have 350Z H-Tech springs,Stillen sway bars(mid stiffness in both front and rear),and SPC rear camber installed on my 04 G coupe. VDC kicked in excessively when I made hard turns during speed driving recently, which was never happened before. I felt the VCD trying to correct the direction of front. My tires are about 80% new,should not have been slippery now. Is there anything wrong with mod I did or the front tires no longer satisfy my driving spirit.
Old May 13, 2007 | 12:29 PM
rhj00's Avatar
I have the same problem too after installing dspecs 7s on a 2004 coupe. Do you have to reset the ECU for the computer to relearn? Anyone out there know what to do besides turning off VDC?
Old May 13, 2007 | 01:21 PM
Skaterbasist's Avatar
Retired SuperMod
Maybe your new suspension mods are making you drive a little harder than usual
Old May 13, 2007 | 02:16 PM
coolb's Avatar
Many people said it is due to different brands of tires in front and rear. My front tires will die out soon, waiting for new tires to see if VDC still misbehaves.
Old May 13, 2007 | 03:04 PM
Retired SuperMod
Yes, some tires have been shown to make the VDC react differently. As for the answer to that issue, if I remember, just use the same type of tire upfront as in the rear.
Old May 14, 2007 | 01:06 AM
G35Luv's Avatar
Just curious, with VDC switched off... I swore it still came on when I was conering... Is there a "2nd VDC" to switch off?
suby01
Not G35 Related
May 25, 2016 03:07 PM
MThawkins86
Oct 24, 2015 02:07 AM
markbilo
Sep 30, 2015 01:33 AM
