Help me lower my 04 G35 Sedan
hey bro, thanks for the fast response
I'm having a killer time trying to find what I need. Do u know if ANY Z revised stock springs+shocks (yr wise) would work on my car?
Your help is greatly appreciated.
I'm having a killer time trying to find what I need. Do u know if ANY Z revised stock springs+shocks (yr wise) would work on my car?Your help is greatly appreciated.
Unrevised = 03-04 z
Revised = 04.5 to 06 z
The difference is the rear spring rates were stiffened from 342 to 427 on the revised setup. If you are looking for a ride that will equal the sedan sports suspension then you want unrevised. If you want a tigher, stiffer ride then go with revised. The choice is really dependent on what you are looking for.
EDIT - I forgot to add, if you are going after the full suspension, get revised. Supposedly the unrevised shocks had some serious bouncing issues.
If you want exact measurements of the drop with Z springs, you can see it here:
https://g35driver.com/forums/g35-sedan-v35-2003-06/109021-installed-unrevised-z-springsyesterday.html
Nice drop, I think i'm going to pick some revised 3z springs from my350z marketplace. Any suggestions on how I should pay for it? Is there any special way I can pay for it and not worry about getting ripped? Or is everything based on trust?
It is based on trust to some extent but you can always review the persons iTrader rating on both this site and my350z. It is similar to the ebay feedback section. Depending on where you are located you might be able to find some local and meet the person face to face. Otherwise most times paypal is used.
Originally Posted by deuceduzit
If I grab a set of the oem g35 06 sport suspensions, which Z springs should i go for??? the revised or unrevised?
Originally Posted by jameyb
No. All sedan springs are the same height with the exception of the X (I don't think you have an X).
See this sticky for a lot of information:
https://g35driver.com/forums/g35-sedan-v35-2003-06/103232-calling-all-x-s-lowered-suspension.html
Pics of the G, does it look drop to you? maybe im retarded?
http://home.comcast.net/~deuceduzit/FRONT.jpg
http://home.comcast.net/~deuceduzit/REAR.jpg
http://home.comcast.net/~deuceduzit/G35.jpg
