Installed Unrevised Z SpringsYesterday
Old Jul 23, 2006 | 05:42 PM
jameyb's Avatar
Installed Unrevised Z Springs Yesterday
I installed a set of unrevised Z springs on my 05 sedan yesterday. I am planning to install a set of coupe springs in the rear (should be here any day now). I went ahead and installed the z springs because I want to be able to compare the rear with both z springs and coupe springs. I will update this post with pics and measurements from the coupe springs when I get them installed sometime next week.
As you can see, the z springs lowered the front about 1" and the rear 1 1/4". It looks great but I think raising the rear a bit with the coupe springs will look better. Thanks to Gsedan35 for the great DIY! I am interested to see how an alignment will turn out.
EDIT: I installed the coupe springs last weekend. As you can see it raised the rear about 1/2". Now, the fender gap in the front and rear are about the same. I think it looks much better. Total drop is now at 1" front and 3/4" rear.
STOCK SPRINGS:
Front Measurement
Rear Measurement
Z SPRINGS:
Front Measurement
Rear Measurement
COUPE REAR SPRINGS:
Rear Measurement
AS IT IS NOW:
Old Jul 23, 2006 | 06:16 PM
DieselX's Avatar
Much better! Thanks for the measurements and pics, it's good reference for newbs.
Old Jul 24, 2006 | 06:16 AM
Grumpy_G's Avatar
I installed an unrevised Z spring yesterday. Handle much better with extra camber. Not sure about coupe rear spring yet, waiting for it to settle a bit first. Didn't have time for a formal photo shoot, so please excuse the clutter.
Old Jul 24, 2006 | 06:25 AM
Grumpy_G's Avatar
Front springs
Rear spring
The height different between the front spring. Same difference for the rear.
3/4" uncompressed.
Old Jul 24, 2006 | 11:31 AM
jawjaw's Avatar
Well done! Love the pics since I have the exact same looking G.
Old Jul 24, 2006 | 12:04 PM
az1anbeethoven's Avatar
looks much better with a drop!!
Old Aug 3, 2006 | 11:20 PM
jameyb's Avatar
Edited to include rear coupe springs measurement for anyone interested.
Old Aug 4, 2006 | 12:45 PM
5150DS's Avatar
Jameyb, which coupe springs did you use. Did you use the standard ones that come with the 18 inch wheels or the sport that come with the 19 inch wheels.
Old Aug 4, 2006 | 12:51 PM
TunerDad's Avatar
GOT MODS?
Hey bro just remember if you need an alignment adjustment due to camber and/or toe being out of spec you will need some more aftermarket parts. Camber kit for rear and new adj. A arms in th front. I'm dealing with that right now form my Z springs. Your car looks good. The more you drive it lowered the more you will love that set up.
tunerDad
Old Aug 4, 2006 | 02:49 PM
jameyb's Avatar
I used 04 coupe springs (18 inch wheels). The spring rate of the 04 coupe matches my stock sport suspension spring rate (342 if I recall correctly). As a result, no need for shocks (I will upgrade to D-specs eventually).
TunerDad, you are right, I absolutely love the way it drives. Ride smoothness is exactly the same as my stock suspension and I feel like there is a bit less bounce with better cornering. Not to mention it looks 100 times better! Even the wife loves it! I can't say how pleased I am with this fairly inexpensive mod. If anyone is considering it, I say just do it, you will thank me.
I am going to take it in for alignment probably sometime next week. Hopefully, I won't be too far out on camber because I really don't want to mess with camber kits, etc. If I can get it within coupe specs as many have reported I will be plenty happy. I will post the results of the alignment when it happens.
Old Aug 4, 2006 | 05:34 PM
CFaber's Avatar
did you order the front Z springs and rear Coupe springs new from a dealer or were they sourced used from various web forums?
this combo looks perfect and I'm a bit keen on using OEM parts where possible.
Old Aug 4, 2006 | 07:26 PM
jameyb's Avatar
I bought the z springs from a user on my350z.com and the coupe springs from a user here. If you post a "Want to Buy" in the classified section you will get replies from several people looking to sell because they have gone with an aftermarket options.
Just a note, I don't know how much you have researched but you want to make sure you get the appropriate springs (i.e. revised or unrevised) depending on whether or not you want to change out your shocks.
Shoot me a PM (or search for posts by Gsedan35) if you have questions.
Old Sep 26, 2006 | 07:42 PM
jimmykce1's Avatar
Revised Springs are stiffer in rear only. Also you will need to replace your shocks or get OEM 350Z shocks with the revised springs.
Unrevised Springs are actually the same as sport suspension that you can get on G35 and you will not have to replace your shocks. However, I do have the sports package on my G35. So I am still looking for an unrevised 350Z springs for my car.
Old Sep 26, 2006 | 07:56 PM
5150DS's Avatar
Jameyb; I love the drop, IMHO it drops the sedan just right without getting too ghetto.
Old Sep 26, 2006 | 09:36 PM
jameyb's Avatar
5150,
Thanks!
jimmy,
Have you checked on my350z.com? There are usually quite a few people who are trying to get rid of their stock springs.
