panhard brace???
Old Mar 15, 2007 | 08:51 PM
PEARL-G's Avatar
panhard brace???
excuse me im a total moron when it comes to this. but do you use a panhard rod/brace to correct rear g camber? i know you use a camber kit for the front, but i heard it was different for th rear?
Old Mar 15, 2007 | 10:40 PM
IvoryGT's Avatar
it's rear tie rod and control arm. There are two bars that needs to be replaced. Try search SPC, it comes with a bigger bolt and a rod. About 135 dollar I remember...
Old Mar 16, 2007 | 09:37 PM
PEARL-G's Avatar
will this correct my rear camber probs?
Old Mar 20, 2007 | 10:05 PM
Curt G's Avatar
IvoryGT already answered your question but I thought I would add that a panhard bar is only used on solid axles, so there wouldn't be one on our cars. It's used to locate the axle in the left to right direction.
Old Mar 20, 2007 | 10:08 PM
Calvin's Avatar
Overglorified Altima
and spc rear camber/toe kit should do you fine. it runs ~200 bucks give or take
the eibach kit is the exact same and about 50 bucks cheaper
Old Mar 20, 2007 | 10:13 PM
Gsedan35's Avatar
Isn't the Eibach kit elongated bolts only, no camber arms?
ScraggleRock
Sep 3, 2015 03:12 AM
jakeup93
Mar 21, 2005 04:50 PM
