Fix for front end creaking noise?
Old Mar 17, 2007 | 07:46 PM
Q451990's Avatar
I hear mine when it's cold... typically going up or down a steep slope (like a driveway crest) and with the wheels turned. Figured I'd wait until near the end of the warranty so it would be easier to reproduce.
Not to be a beiotch, but yeah... pictures would be helpful for me too
Heath
Old Mar 18, 2007 | 06:38 PM
6MTsdn03's Avatar
added pictures
I have attached pictures of: the silicine spray I used, compression rod view, bushings of rod connecting to the frame with lines showing the spraying points (2 pictures), bushing attached to the wheels with lines showing the spraying points. So far everything is quiet.
Attached Thumbnails Fix for front end creaking noise?-img_055101.jpg   Fix for front end creaking noise?-img_054501.jpg   Fix for front end creaking noise?-img_054301.jpg   Fix for front end creaking noise?-img_054401.jpg   Fix for front end creaking noise?-img_054901.jpg
Old Mar 18, 2007 | 07:42 PM
perry05G35's Avatar
I just sprayed mines before you posted up pixs I actually ended up spraying my springs and I'm hoping I got the compression rods as well... It's too dark down there but I don't hear anymore noise. I have my can of CRC in the trunk so if I hear it again I'll give it a couple sprays. Thanks for the pixs though they really help give an idea of where the rods are.
Old Mar 21, 2007 | 04:32 PM
6MTsdn03's Avatar
Has anybody tried it?
Old Mar 22, 2007 | 01:31 AM
OCG35's Avatar
read the whole thread... at least 3 people in this thread say they have...
Old Mar 23, 2007 | 02:01 AM
awong's Avatar
you heard noise on the front wheel right i have the same problem please post picture so i can manage to do it myself thanks.
Old Mar 23, 2007 | 02:21 AM
OCG35's Avatar
5 posts up are pictures... does anyone read the threads before they post?
Old Mar 23, 2007 | 08:50 PM
doogie's Avatar
You guys should try using some gummi-pflege instead of silicon grease spray... the silicon stuff doesn't last half as long as gummi-pflege - at least on door seals and stuff. I imagine gummi-pflege will work great on your bushings too.
Old Mar 23, 2007 | 11:26 PM
KrazyEd's Avatar
yeah I have the same problem...I just deal with it for now!!
Old Mar 24, 2007 | 02:21 AM
awong's Avatar
my bad i was wondering , will the infiniti dealer cover this because im still under warranty
Old Apr 9, 2007 | 04:29 PM
bert039's Avatar
Thanks for the pics!! I'm gonna give this a shot too. My car has been squeaking like crazy lately.
Old Apr 11, 2007 | 09:08 PM
harley01's Avatar
Just dropped my car off for an oil change and mentioned the creaking in the front end. I now have two new compression rods. : )
Old Apr 13, 2007 | 08:38 PM
OCG35's Avatar
did the do under warranty? They upgraded the rears in 05 but at the time I got mine replaced the front were still the same... have they upgraded them now? Or is it just another set of the same ones?
Old Apr 13, 2007 | 09:44 PM
harley01's Avatar
No charge. Didn't ask if they were any different, but I imagine they are the same.
Old Apr 14, 2007 | 11:41 AM
  #30
OCG35's Avatar
Yah, I don't think they have changed... hmmm, I wonder if my dealer will replace mine? They did the rears because they know the previous version was weak and the beefier ones replaced the issues they had prior. I have Stillen anti-sways, so I'm not sure they will replace for me since it's not a TSB or upgraded part – they might try to say the sway bar caused it – hopefully not, they have been pretty good in the past about mods but things are changing a little at Tustin.
The bottom line though is, since it's the same part the squeak will come back again - and I can’t imagine they will keep replacing. Anyway, I'm gonna ask next time I go in.
