Wheel alignment question
I'm dropping my sedan on 06 350z revised suspension. When I get my alignment. should the specs be to the 03 sedan or to the z or coupe specs? I know a camber kit is not necessary but how bad is the wear on the tires without it on the inside?
Thanks Pete
Thanks Pete
i bought a set (unrevised) the other day and the info i have seen says the toe setting for the sedan, z & coupe are all the same. the difference is the camber which has been answered above. just have them set it to the coupes camber of your sedans production year. it does make a difference if someone close to your weight or yourself is in the car when its on the alignment rack.
rezendvous420
May 31, 2020 01:26 PM
