Camber Questions
Old Mar 24, 2007 | 07:49 PM
beatle9999's Avatar
Camber Questions
Getting a rear camber kit for my G, the camber is -2.6, my rear toe is .09 which is still within specs. Would just getting rear camber arms be enouph to fix the problem?? Thinking of getting these http://www.intensepower.com/inreadcaar35.html what do you guys think??
Old Mar 24, 2007 | 08:44 PM
GLuXuRy's Avatar
you can get the SPC toe bolts too while your at it .. its not much .. but ya the camber kit will fix your rear camber... a lot of people run the SPC rear camber kit and toe bolts
Old Mar 25, 2007 | 12:23 AM
Calvin's Avatar
Overglorified Altima
get the spc/eibach camber/toe kit. get that toe back to zero.
Old Mar 25, 2007 | 12:51 AM
Gsedan35's Avatar
I do NOT recommend zero rear toe, you want some toe in on this platform in the rear.
I like the idea of a sperical bearing like that part has, but I've never been convinced that it and all of the identical ebay copies will stand up in use in the long run. IMO, get the SPC camber arm kit that has elongated toe cam bolts. Or invest in a quality part for a camber arm such as the Battleversion arms if you much have a non SPC arm.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
