rear axle issue- need help quick
Old Mar 30, 2007 | 11:16 PM
myGspot's Avatar
I was just changing my brakes f/r and everything was fine till i discovered something scary. As i took the rear driver side wheel off, i noticed that the rotor hand the hub had some play in it. At first i thought it was just the rotor and i was seeing things, but once the rotor was removed, i discovered that the hub itself had some play to it. It was moving pretty freely and you could easly see there was a problem in it.
The only time the rear end on the car was touch is when i went to the dealer for the TSB on the rear axle click. I never bothered checking the work and now after little less then a year i discover this.
I am not certain as to what could have happened. I can think of the nut on the hub wasnt tightened properly or not torqued to the proper specs. The bearing inside the hub could have worn out or became damaged somehow ( possible due to the faulty work during TSB. Also, a very remote chance of premature wear.
has anyone here experienced such a problem? If so, how severe is it?
for point of reference its a 2005 with just about 30k miles
Old Mar 30, 2007 | 11:31 PM
RichardxG35's Avatar
do you hear a click click sound too>?
Old Mar 31, 2007 | 12:47 AM
myGspot's Avatar
no i do not hear any sounds at all. But the hub moves freely. the passanger side is good however.
I have notice a hum when going 80+ coming from the rear... now i'm wondering if it has to do with the hub not being solid
Old Mar 31, 2007 | 12:55 AM
hmm.... cause recently my friend rear axle has problem too is a 05... at first i thought is because his 20"s was too heavy.. he put back his stock wheels an it still there.. everytime he put in to gear it have a click click sound coming from driver side rear axle..
Old Mar 31, 2007 | 01:07 AM
myGspot's Avatar
have him check it out. The first time i had that was due to lack of greese in the axle. It was an easy fix at the dealer. But what i have now is a bit more then the click i had a while back(which is what your friend has)
Old Mar 31, 2007 | 01:12 AM
thanks i give him the message..
Old Mar 31, 2007 | 06:16 PM
myGspot's Avatar
well just as i thought... wheel bearing failure (premature wear) i did not see the extend of the damage but it was pretty bad according to the dealer.
Goes to show you that you should always keep an eye on your own car.
jsimonk
Dec 22, 2023 03:49 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
Soumilg
Jul 18, 2015 12:33 PM
