Will i Rub??
Old Apr 10, 2007 | 04:15 PM
nghiars's Avatar
Will i Rub??
Im running on 19x8.5 fronts and 19x10.5 rears wrapped in 245/35/19 and 275/35/19 toyos t1R, and im planning on loweirng it with tanabe df210's...
Those with the tanabe df210's... will i be clear or is there going to be rubbing issues?
Thanks
Old Apr 10, 2007 | 04:22 PM
Calvin's Avatar
Overglorified Altima
Thanks
...what offsets are you running? the front will be fine...
the df210s are a huge drop...but your 275 tires help...
Old Apr 10, 2007 | 04:26 PM
nghiars's Avatar
i think they're +29 up front and +25 in the rear.. i'll double check when i get home
Old Apr 10, 2007 | 04:41 PM
BadBoy06's Avatar
should be close..real close
Old Apr 10, 2007 | 05:40 PM
Disco_Monkey's Avatar
I was running 9.5F +28mm 245/35/19's and 10.5R +23mm 275/35/19's and no rubbing.
Old Apr 10, 2007 | 07:16 PM
Calvin's Avatar
^^how much were you dropped?
Old Apr 10, 2007 | 10:16 PM
nghiars's Avatar
ok i double checked and had the offsets mixed up... its +25 up front and +29 in back
Old Apr 11, 2007 | 12:42 PM
nghiars's Avatar
thanks for the input guys
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alinero718
Sep 27, 2015 09:35 PM
