Early Z Sways F/R on G Sedan - Better/Worse/No Difference?
Old Apr 25, 2007 | 07:31 PM
dahkyne's Avatar
My '06 G sedan is currently on UN-revised Z susp., which certainly improved the handling at a slightly stiffer ride... Along with the springs and shocks, I also got a set of front and rear OEM 350Z sway bars from the same car...
Will they fit, and would there be an advantage in getting these Z sway bars installed? If not, why? If so, why?
Old Apr 26, 2007 | 11:29 AM
gramdacious's Avatar
I believe the Z sways are the exact same as both the G sedans and coupes thus giving them no benefits over our stock setup.
Old Apr 26, 2007 | 11:54 AM
dahkyne's Avatar
Cool. Can anyone else confirm/deny?
I may have a set of Z sways for sale if this is the case...
Old Apr 26, 2007 | 05:27 PM
Q45tech's Avatar
Tires are 90% of handling and suspension is at most 10% and modifications are hard pressed to yield 1,2,maybe 3% improvements.
Study the tirerack suspension tests on BMW here the tried springs, sway bars, shocks from different manufacturers..............a glorious 1.6% improvement.
Don't confuse the angle of steering wheel [over/understeer] or the harsh ride with improving skid pad, slalom, or track loop times.
Feels better is so subjective.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
itschuckster
Jul 25, 2015 08:07 AM
