i want to drop it.
Old May 1, 2007 | 02:43 AM
perry05G35's Avatar
ttrank they look like stern wheels pretty inexpensive on eBay.
Old May 1, 2007 | 10:41 AM
clinthammer's Avatar
will these teins work
http://mynismo.com/products/?id=3126
Old May 1, 2007 | 12:53 PM
perry05G35's Avatar
H Techs if you want brand new springs or 350z spring and shocks if you want progressive springs at all 4 corners and OEM parts plus I think it makes for a better selling point if you ever sell your car you can say it has the upgraded 350z sport suspension. You should be able to get both 350z spring and shocks for the price of a new set of H tech or any other aftermarket spring alone so it's a good value. I had Eibach but I switched to 350z/G35coupe springs on my stock sport suspension shocks. The drop on the 350z?G35coupe spring is more even than my Eibach drop which was rakeish....
Old May 1, 2007 | 08:59 PM
oooooooooooooq's Avatar
would i have to be concerned about any rubbing on the wheels, i took pics but i cant find the cord to the camera. also if i want to go cheaper will just the 350z springs provide a good drop ( for now, untill i get the tein flex).
Old May 1, 2007 | 09:02 PM
redlude97's Avatar
OEM 350z springs aren't progressive
Old May 2, 2007 | 12:10 AM
will the z/coupe springs or even tein s/h techs adversely affect the drivetrain/axle in any way? When i get home im dropping my ride on Rs rims with a 19x8.5 front +38 and 19x10 +45 rear.
I just want a 1inch drop and dont want to mess up my axle or camber etc.
Basically are the springs install a basic remove old ones, install new ones and drive off or else?
Old May 2, 2007 | 12:14 AM
OSKIRE's Avatar
do they work for coupes?
Old May 2, 2007 | 02:41 AM
G SEDAN's Avatar
Originally Posted by ttrank
Do you have any more pics? Those look like the split 6-spoke DPE's I was looking at.
I wish those were the DPE R06's...I wanted them too but was too expensive for me. They are the sterns, cheaper alternative but they are strong. heavier obviously but i guess it wouldnt hurt me as much if i ever dented it on the freeway. I was able to affrod a full size spare
Old Jun 13, 2007 | 03:13 AM
deanfootlong's Avatar
i have a g35 coupe. would it be best to just buy the 350z springs? or springs as well as shocks form the 350z? anybody have any info on whats the best combo here?
Old May 5, 2008 | 09:59 AM
if i got tein coilovers, what kind of camber and toe stuff would i need to buy?
Old May 5, 2008 | 10:04 AM
MikeYo's Avatar
Originally Posted by Nismo G
If you just want to drop it go with 350z h-techs by Tein or get Tein basic coilovers. They will both provide you with a happy drop.
-Sean
i want a HAPPY drop!
Old May 6, 2008 | 09:32 AM
no one has answers?
Old May 7, 2008 | 09:24 AM
so, i would need, toe bolts and a rear camber kit, and in the front just a new a-arm?
Old May 7, 2008 | 09:43 AM
snavematt's Avatar
just a sedan
I used SPC front and rear kits, worked fine, rears are cheap, fron is not cheap
jsimonk
Dec 22, 2023 03:49 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
joedaddy1
Jul 28, 2015 02:58 PM
