Suspension Question
Old May 3, 2007 | 05:40 PM
HellaFly's Avatar
Suspension Question
well my 350z suspension is being put in right now...and my mechanic just called me and said the shock absorber is seized..and the only way to get the shock out is to replace the control arm?...he said he called Nissan...and its 410 dollars per side ...he said he could replace the spring so it would still be lowered...
is there anyplace else i can get the control arm for cheaper?...is it bad to be driving on the seized shock absorber?..any help would be great...thanks ahead of time
Old May 4, 2007 | 12:43 PM
Tytanium's Avatar
Why would you need to replace the control arm? The shock itself has nothing to do with the control arm.
Old May 4, 2007 | 01:35 PM
jameyb's Avatar
+1, what you are being told doesn't make any sense. If you have a bad shock at most you would just need to replace it. Is it the 350Z shock or OEM shock that is seized (I am assuming that means it is locked in place)?
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
