grabby Squeaky brakes on an 03
Old May 7, 2007 | 05:53 PM
Edmo's Avatar
Question grabby Squeaky brakes on an 03
I purchased a used 03 G35 sedan and it has grabby squeaky brakes. I noticed the same issues with several others that I test drove. Is this a design issue that I need to learn to live with? The Dealer replaced rotors and did a full brake service before I took delivery. Is there a alternative pad that will fix this?
The Brakes also squeak at light pressure and low speeds. Not as big a problem but I would like to eliminate that as well if possible.
Old May 7, 2007 | 06:26 PM
GLuXuRy's Avatar
03-04 non brembo brakes suck .. mine squeak like crazy at low speed .. as for grabby .. i deno what to tell you there .. our brakes are grabby in general .. so it just takes some getting used to
Old May 7, 2007 | 06:39 PM
ttrank's Avatar
Grocery getter
It's the pads more than anything else. The rotors are a bit too small so they tried to compensate with very sticky pads.
Try some Hawk HPS pads next time.
Old Jun 22, 2007 | 12:34 PM
Edmo's Avatar
Thumbs up
Thanks for the tip! I purchased some Hawk HPS front pads on line for $66 and replaced my factory pads. It only took about 30 Min and made an immediate improvement in my ability to modulate the brakes. Anyone that feels their brakes require too much thought to operate smoothly should look into some non factory pads.
Overall performance seems similar and the squeak has not returned yet.
Old Jun 22, 2007 | 01:08 PM
ttrank's Avatar
Grocery getter
Did you make sure to follow the break-in procedure for the pads?
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
