Sway bars...
Old May 11, 2007 | 01:32 PM
HondaCRX's Avatar
Sway bars...
looking for some experiences that people have had.... primarily with data to back up seat o' pants feel.
I'm in the market for sway bars. or maybe just a sway bar.
But, when building my CRX, i found that an aftermarket front bar was over kill... and only really need a rear sway bar to get the car to pivot.
So, before I go out and buy a set of sway bars for my G35... I want to know if anyone has any experience with this. Would the purchase of a front bar only be necessary to reduce body roll and to get the car to rotate more naturally? Would only the rear bar be necessary? are both the best in terms of reducing roll, improving turn-in, and camber grip on corners?
also, which diameter seems to work the best? 21mm rear? larger? what about the fronts?
Old May 11, 2007 | 01:33 PM
izmir41500's Avatar
G35driver Addict
check out the sticky in the suspension section.
Old May 11, 2007 | 02:14 PM
ttrank's Avatar
Grocery getter
Get a set of Stillen or Hotchkis sway bars and you will be very happy!
Old May 11, 2007 | 10:18 PM
kenasaki's Avatar
OH MAN! my 1990 crx si was stolen from me too!! that was my baby! they stripped it for all my overseas parts. but they stole mine in august. got pics of your ride?
Old May 11, 2007 | 10:19 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
+1
-GP-
Old May 11, 2007 | 10:43 PM
vodkarocket's Avatar
Modded Member
Get a set of STILLEN sways. Hotchkis don't have collars, so they slide and make noise.
Old May 11, 2007 | 10:48 PM
nate4598's Avatar
+1 for stillen sway bars
Old May 11, 2007 | 10:49 PM
BadBoy06's Avatar
+1000000
Old May 11, 2007 | 11:08 PM
Augy's Avatar
Hotchkis!!!
Old May 11, 2007 | 11:16 PM
Concealed StrateG35's Avatar
Most come as a kit (front and rear) so why worry about if the rear is necessary, it's going to be better than stock.
IMO here at the best.
1. 350EVO Sways
2. Stillen
3.Hotchkis
Old May 12, 2007 | 12:11 AM
Augy's Avatar
350evo's are tight but isnt the price expensive?
Old May 12, 2007 | 12:57 AM
poorman's Avatar
Get Stillen sway bars good stuff and cheap. Or you can spend another $50 more and get Eibach sway bars, they are just like the Stillen bars except they have red polyeurethane bushings. You can get both bars at www.Stillen.com
Old May 12, 2007 | 07:26 AM
perry05G35's Avatar
^ the Stillen sways are 299 on stillen.com I went ebay and found a seller that has buy it now of 299 or best offer so you can get them cheaper here plus he has 97 available so I see the potential for a good deal...
Old May 12, 2007 | 08:00 AM
izmir41500's Avatar
G35driver Addict
The new ones have collars. I have them on the Hotchkis that I bought. Comes with polyurethane bushings and grease too.
Old May 13, 2007 | 05:50 AM
wescastle's Avatar
I saw these too... do they fit the 03-04 sedans tho? only says 350z and g coupe.
