55k miles-- do I need new shocks?
Old May 23, 2007 | 05:12 PM
CalRSX07's Avatar
My ride quality feels like it sucks compared to the way it used to feel, and it seems bouncier than it used to be. I'm at 55k... what do you guys think the likelihood is that it's time for new shocks? How long should one be able to last on OEM suspension? Thanks!
Old May 24, 2007 | 08:49 AM
Q45tech's Avatar
Depends on the roads, passenger weight, temperature, tires and wheels.
I have never heard a client complain after getting new oem shocks, they always notice the difference.
Old May 24, 2007 | 09:16 AM
cato's Avatar
SouthernComfort Moderator
Well, I have 93,000 miles on my sport tuned suspension and it still feels OK...
Old May 24, 2007 | 09:33 AM
Metalp3n's Avatar
I am at 59K and just changed out to a 350z setup last night, and I must say the ride feels alot better. Around 55k the suspension I had started to be a little more bouncy, and started making alot of rattles as you drive.
Old May 24, 2007 | 01:11 PM
CalRSX07's Avatar
do you recommend the 350z setup? is it stiffer and better handling? if yes, thats great--but i also want to keep a comfortable ride (if i didnt, i wouldve gotten springs a long time ago haha)
Old May 24, 2007 | 01:58 PM
codeflux's Avatar
i just got my sport OEM suspension with 80k miles on it changed over to Tokico D-Spec & Eibach Pro Kit springs setup. very happy with the results. DEFINITELY worth it. OEM setup is much more wobbly in comparison. see pics and review: https://g35driver.com/forums/brakes-suspension/158524-tokico-d-spec-eibach-pro-kit-sedan-review-pics-54k-maybe.html
Old May 24, 2007 | 02:09 PM
GGRJR's Avatar
It depends on how sensitive you are to what the car is doing. Usually anything over 20,000 you can start to see some change. Do they really need changing probably not, but you are the only one that can determine that, unless they are just flat wore out, or damaged, leaking etc.
Old May 25, 2007 | 04:57 PM
CalRSX07's Avatar
if i take the car to a mechanic (or ****, one of you guys..), will they be able to drive it and tell me if the shocks are worn or not? is there any way to check to see, without just the subjective 'they feel bouncier' type of feeling?
Old May 25, 2007 | 06:22 PM
Sac2904's Avatar
I am on 60K on my 04 coupe and the shocks are just fine. I guess mostly I just drive it by myself, no extra passengers!!! What is the standard mileage before changing these socks or it should base on feeling boucing or visual inspect???
Old May 25, 2007 | 06:28 PM
gary c's Avatar
It's time........
With my last car I could tell the difference from one day to the next. When my
300ZXTT started feeling like my wife's old Monte Carlo it's was time to get new dampers. Nothing worse than bouncing down the road when you realize
you tight ride is gone!
Marlin84
Apr 1, 2020 12:52 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
TheBay
Sep 3, 2015 03:27 PM
