Will Brembo coupe brakes fit an 03 sedan?
Old May 30, 2007 | 12:06 AM
ttrank's Avatar
Grocery getter
That is true. You don't want to upgrade the rears without the fronts because the bias will go to the back and cause lots of problems.
Old May 30, 2007 | 12:35 PM
04NismoV35's Avatar
BTW, you'll need 15mm (actually 12.5 might work, but are hard to find) spacers to run stock wheels unless you get the coupe wheels. I'm doing both so I can run my stocks for winter and so I can have summer rubber again. I have yet to install mine tho.
G/L, OEM Brembo's are a hard and pricey find. I got lucky on eBay, check the classifieds here as well.
Old May 30, 2007 | 06:52 PM
maliy06's Avatar
Thanks for the info
Old May 30, 2007 | 11:14 PM
dklau33's Avatar
Originally Posted by maliy06
Do you guys thing its a good deal if two rear used Brembo caliper for $200. The calipers are from a burned car. But you could see the suspension was not burned
That's practically a steal but be sure they are in working order and did not get damaged from the fire. Brakes are the most important thing on your car.
Old May 31, 2007 | 05:13 PM
04NismoV35's Avatar
There was a set of front Brembo calipers in the classifieds recently. I dunno if its still there tho. Brembo's tend to move quick.
Old Mar 4, 2008 | 08:42 PM
Rodrigo's Avatar
back from the dead,
After reading this thread is it safe to assume that the 350z brembos are compatible like the coupes as long as you run the correct wheel . ?
Old Mar 4, 2008 | 08:54 PM
redlude97's Avatar
Originally Posted by Rodrigo
back from the dead,
yes, they are exactly the same
teamghost
Jul 28, 2015 04:52 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
