Poly Urethane Bushings?
Old Jun 5, 2007 | 09:25 AM
Mad Paradox's Avatar
J-Dizzle
I'm looking for a set of good poly bushings to replace the OEM ones for the Cusco Sway Bars the Front sway bar is 35mm and the Rear sway bar is 22mm.
Part numbers would be great along with tips on where to get them from or order from. Thank you and any leads are greatly appreciated.
Old Jun 5, 2007 | 12:35 PM
dklau33's Avatar
Prothane makes poly bushings for the sway bars in oem sizes. But these will still fit fine on the slightly larger cuscos.
Front Bushings
Rear Bushings
Old Jun 5, 2007 | 12:48 PM
dream_G35's Avatar
got mine from summit racing. Cheap, quality product, and quick shipping.
Old Jun 5, 2007 | 01:33 PM
J-Dizzle
Thank you for the tips also, is there any bushing kits for the endlinks that you could recommend?
Old Jun 5, 2007 | 01:38 PM
G35Luv's Avatar
Front Bushings
Rear Bushings
Would these fit the Stillen Sway Bars?
Thanks...
Old Jun 5, 2007 | 02:09 PM
dklau33's Avatar
Thanks...
Yup, they fit jsut fine. I have them on my Stillen Bars. If you don't want to hassle with regreasing the poly bushings periodically you can reuse the stock rubber bushings if you wish.
Old Jun 6, 2007 | 11:18 AM
G35Luv's Avatar
Thanks... Yeah I have the stock rubber bushings right now... and was hoping these would help with making them stiffer.
Old Jun 6, 2007 | 03:08 PM
erdog's Avatar
What would changing the bushings improve?
Old Jun 6, 2007 | 06:08 PM
dklau33's Avatar
It just removes the slop that the rubber bushings have. Only comes into play when driving your car hard around corners or to the limit on the track. And even then you'd be hard pressed to even notice the difference.
Old Jun 7, 2007 | 12:12 PM
G35Luv's Avatar
It that's the case... then.. hmm.. I guess I'll change it over to the Stiffer slot first then... it's on Med/Med right now.
Old Jul 10, 2007 | 02:24 AM
bambam26's Avatar
I have a set of poly bushings I just took off my sways they have less than 1k miles on them. I sold the car and the sways and have the bushings left...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
