which sways?
Old Jun 14, 2007 | 08:52 PM
freak21s2k's Avatar
which sways?
hey, im looking to purcahse sway bars but not sure which i should get. should i get the eibach sway bars or stillen sway bars. thanks
Old Jun 14, 2007 | 08:57 PM
redlude97's Avatar
almost any set of adjustable sway bars will be fine. the key is the adjustability so you can set them to the stiffness you are most comfortable with
Old Jun 14, 2007 | 09:45 PM
freak21s2k's Avatar
are both stillen and eibach adjustable?
Old Jun 14, 2007 | 09:53 PM
GreenGoblin's Avatar
The goblin resurrection
i know stillen is not sure about the eibach tho
Old Jun 14, 2007 | 10:09 PM
Zerk's Avatar
Hotchkis makes a nice set with bushings included. Stillen's sways are pretty good too but require you to use stock bushings.
Old Jun 14, 2007 | 10:21 PM
freak21s2k's Avatar
ic. are they hard to install? and would you guyz recommend getting springs? because i know i am not going to get coilovers but i was considering springs but not sure if its worth $200.
Old Jun 16, 2007 | 02:29 AM
Calvin's Avatar
Overglorified Altima
350evo, stillen, hotchkis. all great choices.
Old Jun 19, 2007 | 09:35 AM
izmir41500's Avatar
G35driver Addict
i have hotchkis. only reason i didn't install them myself was because i couldn't break the bolts loose. i couldn't get enough leverage with just jack stands holding the car up. a lift is almost necessary unless you can get your car decently high with ramps or something. they're very easy to install. check out the instructions on 350z-tech.com
rezendvous420
May 31, 2020 01:26 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
linedr89
Aug 17, 2015 05:11 PM
